1986 Iroc Procharged 408
#44
#45
Finally got around to checking the runout on the quicktime bellhousing. These past few weeks have been very busy.
After making 3 passes at it, I'm only .004 out. Within spec, all is good.
I'm glad I mocked the bellhousing up, because I got a some clearance issues with the 2" headers. The driver's side is worst, you can kinda see it in the picture. I'll have to grind off about 1/8 - 1/4 of the bellhousing in that area. Checked the passenger side too. Just have to grind a little off around the starter bump. I hate to grind brand new shiny pieces, but I got to.
#48
Thanks guys.
Had some time this week to trial fit the Hawk's T-56 crossmember and the Spohn piece.
Hawk's fitment was not so great. I think all 4 hole slots need to be lengthened.
The Spohn piece fit awesome, but DANG it hangs low, no way anyone could get exhaust around that thing.
So my plan is to morph the 2 together. So I can run exhaust and use a torque arm.
Also, I'm probably going to have to move the fuel lines, because the Hawk's interfere's with them around the end of the transmission.
The Hawk's piece has the right idea, but it just really needs some refinement.
I'll get some pics, when I have a chance.
#49
Have you looked at the new Hooker crossmember? Looks nice but can't remember what k member you have. Will not work with the BMR one like I have.
I made my own from the Hawks piece and the Spohn piece as well. Still had to oval out the holes though.
#50
Ricky,
Thanks for the pics!
Pretty much exactly what I had in mind. Nice job too.
From what I've seen I'm not going to mess with the Hooker piece.
How much power are you putting out?
I almost want to box-in the cross piece more? Just a tad nervous at my power level.
Thought about a tunnel mount, but 99% sure it would interfere with the driveshaft and I'd rather have a longer torque arm.
I have a UMI K-member.
#51
Ricky,
#52
Ricky, Sounds like I have the same idea as you. I'm going to run a 3 inch y-pipe into my flowmaster merge, then a 4" catback.
I think for now I'll just copy your piece almost exactly, then later once everything else is wrapped up I'll make my own.
Continuing on this weekend, I was able to install the Monster twin disc clutch. Had a quick question for Steve on the install, and he responded like 5 minutes later, impressed. Clutch went in easy. Can't wait to try it.
You can see where I trimmed the back plate of the bellhousing. I'm sure it's not SFI rated anymore, oh well, at least it fits.
I placed the intake on, just to start see where things are going to route. I'm using Fast fuel rails and 80 lb Bosch injectors from FIC. Jon was a major help and suggested these and at a great price! Sent me data on them as well. Should be plenty for my application.
#53
Got the Bellhousing in. It was definitely tough getting to all the bolts.
Does anyone know a part number or a size for the (2) bolts for the bellhousing to oil pan? Also, are those really needed? Kinda seems like a bad idea to me?
Also, was able to measure for the slave shim. Glad I did, because it was way off. Although Steve from Monster predicted it when I told him I was running the quicktime bell. I ended up using both thicker shims from the (3) pack from Tick. My "B" is less than "A" (See shim thread)by .104" so should be good now. Only pic I had, my hands were full with the straight edge and calipers.
The spring is removed, and I had both shims behind the slave.
Another small thing was the oil pressure sensor for the Holley EFI. I'm using the stock oil pressure sensor for the dash gauge. My plan was to use the spot above the oil filter for the Holley gauge. It's pretty dang close to the header, only have like 1/8" clearance. However, it's only at a small point. I angled the sensor forward, somewhat perpendicular to the header tube, to try to get it away. Thoughts, opinions? Sorry, for the blurry pic, kind of a tight area. I'll have to get a pic of the side, there's a lot more clearance for the sensor then what the picture shows. The tightest spot is the small 90° fitting.
#54
I think I finally finished up the power steering!
I'm using a C6 P.S. pump. modified with -AN fittings.
A canton remote reservior.
Decided to get rid of the old steering shaft. Bought the parts from flaming river. 2 u-joints and one of there "universal" shafts (it's collapsible). It's shiny and it gets rid of the rag joint, lol.
Pump & lines:
Remote Reservior:
Steering shaft: ( I can dig up the part numbers I used if someone wants, cant' remember them off hand)
Next step Trans install!!
Pump & lines:
Remote Reservior:
