1995 S-10 turbo build
Installed the transgo HD kit yesterday. I followed denmah's video as a safety guide since I've never messed with a valve body before. The install was pretty simple. The trans fuild was pretty dark for amount of miles on it.
Also got my circle D torque converter today. I'm really impressed with this company so far. The customer service was legit when I was trying to figure which converter to order and it came professional boxed with instructions which is always nice.
I don't know why everyone went on about the valve job, when the factory didn't do a 3 or 5 angle valve job, just a single angle seat. Do the guys who posted that actually think you lapped those in soooo much, you removed a entire angle or 2?
I lap them in until they hold liquid. Once they hold liquid, they are good.
Good progress.
Good progress.
Got my turbo drain bung welded in. Ran into a little problem trying to weld the top side of the fitting because the oil pan lip sticks way out! The welds are pretty ugly.
So I just welded the inside instead of making a huge mess trying to get my torch in the small area.
I used cpw mounts for my swap. Set all the way forward, and have room after recessing the stock 4.3 rad into the core support using truck accessories. Should still be enough room to sneak in a merge pipe.
Made some progress..
Seated the converter, mounted the trans to the motor, installed new oil pan, bolted timing cover on, now I just need to get the crankshaft pulley on!
Here is a comparison of a red and blue oil pan pickup o-ring. I got a blue one with the ported oil pump and red came with the GM muscle car pan.
Converted the radiator to dual pass today.
The welds look like hammered dog poopy but oh well.
I've never had such a problem welding aluminum as I did today.
I'm thinking it was because I used a 4.5 angle grinder to cut it open and I normally use it on steel.
WAY TOO THICK but it's what I had laying around!
Everything is looking good man!
But one thing I can tell you from experience don't start marking the turbo kit out of the truck it is EXTREMELY tight in these trucks and I played hell getting everything to fit perfect doing it in the truck.
Nice drain back location that's the same spot I used.
Can a MOD move this to the forced induction section.
I have to figure out which turbo oil feed setup I want to run.
Option 1 I like this the best just not sure if it will clear the firewall.
Option 2 might be able to run this if clearance is a issue.
Option 3 would have to drill and tap the oil cooler bypass plate.
Thanks for the advise. I'm definitely going to wait because I have a bad feeling these manifolds are going to hit the steering shaft. I want to set the motor in the next 2 weeks. I'm just waiting on funds so I don't have the truck apart for weeks and weeks.
#33
#34
I would run the oil feed on the side of the filter housing cause then you know the turbo is getting good filtered oil right from the source. This is how I did mine.
#35
I'll lay money they will hit haha i notched my driver side manifold for my steering shaft and I even have an aftermarket 3/4 dd shaft steering shaft.
#37
Does anyone know what this know what this grey stuff on the internals is? I'm guessing LSD clutch pack material. The oil looked clean coming out so I'm going to say it isn't bearing material.
Going to try and clean up the rotors/calipers with a wire wheel. Have to replace the parking brake pads though.
#39
Cleaned up the rear and caked on chassis savers I had laying around from another project I did. The parking brake pads weren't too bad to replace just needed needle nose pilers and a flat head screwdriver. I'm thinking about getting GT500 wheels since they are 7.125 backspacing and almost fit the stock width 8.8 in the s10 perfect.
Rattle canned the calipers after I hit them with the wire wheel.
Water pump installed and cut the alternator bracket since I'm not running P/S.
Cut up a skid plate I had from a old truck and made a plate to cover the 5 speed hole and it brings the shifter up a few inches to a more comfortable position.
Poop welds again.. but I polished it anyway.
Ordered injectors, exhaust tubing and small things I plan to make a lot of progress this week/weekend.
