Petro's ERL Superdeck 427 w/ Whipple 2.9L
#123
The other catch can didn't fit like I thought it would where I wanted it to so I got a different one. This one has -10an ORB fittings, stainless steel media packed baffle, o-ring sealed screw on canister, dipsticks, and -4an drains. The breather filter is a Aeroflow -8an screw on with stainless steel filter media. The one with the -10an fitting was too large of a diameter and would've looked weird on the catch cans. I also got Atomic to custom mount the Lokar pedals I've had laying around forever.
#124
Are you spending you 401K? LOL. You have such nice stuff going into bad *** ride.
#126
Thank you for your service !!!
#132
What your thoughts on this?
If you look closely at the after pic you can still see valleys/grooves which will still retain oil. My thought process was that polishing will remove the burrs and turn the "V waves" from grinding into "square waves" creating more surface area while still maintaining the valleys for oil retention. I imagine looking at it mircoscopicly from the side and straight on. The valleys are still there but I "averaged" out the peaks by polishing creating a stronger plateau surface area. If it eats itself then it's my fault.
#133
I am pretty sure that high-end race engines have their crank and rod journals micro-polished. I think as long as you are not changing the cam dimensions, polishing would be a good idea.
I don't have direct experience with this, but that's my thought process.
Andrew
Andrew
#135
I just read this and now I am thinking I wouldn't mess with it...LOL
http://www.enginebuildermag.com/2005...smooth-enough/
Andrew
Andrew
#136
I'd bew too afraid to try and buff a cam. Used on is a different story. Thanks for sharing.
#139
I wish...I may get a large vibrator polished with chemicals when I get a actual shop. I have a side hobby of polishing stuff...detail paint , polish metals, hell I even polished the concrete floor in my garage... Its just a bench top buffer with polishing wheels and jewelers rogue.
