TCC Break and Vss question
Old 04-24-2016, 02:59 PM
Monkeyman0330's Avatar
Exclamation TCC Break and Vss question
Hello, I'm swapping a 5.3L engine into a 1980 camaro and had a few questions about the TCC and the VSS. I have my wiring harness down to the needed wires and plugs, but my question is I have a sensor hook up for both the TCC and the VSS and I also have a wire for each coming out of the computer, do I just use the wire that comes out of the computer or do I also need the sensor plug?? Any feedback would be appreciated,
Thanks,
Ryan
Old 04-25-2016, 10:14 AM
1964SS's Avatar
Welcome to LS1tech, I think your confusing them with each other a bit. You will have a speed sensor that sends an input to the PCM and you will have a speedo output off of the PCM that will operate your speedometer if you have an electric speedo. You need both unless you are T-tapping off of the speed sensor to drive both the PCM and speedo.
The TCC is not a sensor, it is the control to torque convertor and the other wire off of the PCM will normally go to a newer style brake switch so lockup will release when you press on the brake pedal. Look up some of the wiring on LT1swap. They will have what you are looking for.
Old 04-25-2016, 11:20 AM
Thanks for replying, I have a mechanical speedo, so which one can I elimate the wire coming off of the PCM or the plug sensor?? Thanks
Old 04-25-2016, 11:43 AM
1964SS's Avatar
You will not need the speedo output from the PCM if you have a mechanical speedo. What transmission are you using?
Old 04-25-2016, 11:46 AM
Im using a th350, so I need the sensor plug? I dont understand how the dakota digital sensor hooks up to the plug?
Old 04-25-2016, 01:36 PM
1964SS's Avatar
th350 is mechanical speed output. I'm assuming you bought a dakota digital pass through pulse generator? This would allow you to still use your cable drive speedometer and offer a electronic VSS output to send to the PCM.
Old 04-25-2016, 08:34 PM
Yes I bought a speed pulse generator, it comes with two wires a ground and a output for the Pcm, do I connect this out put to the sensor plug? And if so there is two wires going to that plug,
Thanks for all the help,
Ryan
Old 04-26-2016, 07:58 AM
1964SS's Avatar
Yes, Your PCM sensor plug has two wires and they will connect to your pulse generator wires. There is a high input and a low input. The ground is the low.
Old 04-26-2016, 08:35 PM
Thanks a lot that helps a lot
Old 04-26-2016, 09:11 PM
I know this doesn't pertain to this topic but I tried to install my th350 transmission today on my engine and found that it hits the torque converter and is about 1/2 an inch from touching the back of the engine?? I honestly don't understand why this is happenings?
Old 04-27-2016, 08:44 AM
1964SS's Avatar
Sounds like your torque converter isn't seated completely or you've got your spacer bolted on incorrectly. You bought a spacer kit right? If you've got a dished flexplate then the spacer installs on the outside. If you've got a flat flexplate then the spacer mounts between the flexplate and crank snout.
Old 04-27-2016, 08:59 AM
Restricted User
JoeNova's Avatar
Your torque converter likely isn't seated all of the way. Very common problem. Spin it while pushing in until it is farther onto the input shaft.
Also, which flexplate/spacer combo are you using?
Old 04-27-2016, 02:39 PM
Yes I bought a spacer kit and I have the dished flexplate and the torque converter is a1/4 inch away from the flexplate, I cant figure it out either
Old 04-27-2016, 02:44 PM
1964SS's Avatar
Torque converter must not be all the way seated then. sometimes they can be a hassle. Just keep spinning and pushing it in. You will feel it when it slips in the last bit.
Old 04-27-2016, 02:50 PM
My torque converter bolts to my flexplate, if the bolts are all thw way in it still doesnt mean its in all the way?
Old 04-27-2016, 05:10 PM
1964SS's Avatar
Your torque converter slides over the splines on the transmission input shaft. If it is not completely pushed on then it will hit the flexplate before your transmission bell is seated against the engine block.
You previously stated your torque converter hit before the transmission was up against the engine. If your now stating that the transmission is now bolted to the engine and torque converter doesn't quite reach the flexplate then you simply pull it out a hair and bolt it up.
Quick Reply: TCC Break and Vss question
