AC Inputs-No Response, 5.3L LM7 Swap
I recently received a mostly complete '84 CJ-5 running an '01 LM7 using the factory PCM and harness. The truck runs a vintage air system (Gen II) with an R4 compressor which when coming to a stop with the AC on bogs the truck down until it dies. I am trying to integrate the system into the ECM so that the ECM will kick up the idle when coming to a stop. I have added wires back into the ECM C2 connector at pins 11 Circuit 604 Dk Blue (A/C High Pressure Switch) 17 Circuit 762 Dk Green/White (A/C Request) and 55 Circuit 603 Dk Green (A/C Switch) and am monitoring the PCM with a scan tool to see the results. I am putting the appropriate inputs in (Ground on Circuit 604; Power on 762 and 603) but seeing no results on the scan tool. I am tuning with JET DST and am wondering if the "Type of A/C on Vehicle" prompt under System Parameters may have something to do with this? I have found no info anywhere on what that prompt may mean? Any other ideas as to why I wouldn't receive a response? Any help would be greatly appreciated!
Let me look at that again but I was inputting on those circuits and seeing no response on the scanner; I am seeing RPM fluctuations and everything else but no response from inputs on the AC system.
