C5 LS1 Alternator Wiring Question
Hello LS1Tech,
I've searched and read plenty of the material on this, but I am still having a hard time understanding if I need to change anything with my set up. I am using 00' C5 LS1 with F-Body style engine harness and ECU. My charging system dummy light on the dash is constantly staying on from the moment I turn they key to ACC position. At first, I thought that the alternator was sending a signal telling me that it's bad, but further research confused me beyond recovery on my own haha.
Here is what I am using as a reference:
1) According to the diagram, my dash dummy light will stay on no matter what as long as it's provided ACC and plugged in to the alternator which is proving the ground. I don't get it, is the alternator light suppose to stay on on GM cars?
2) According to some other threads, I only need to use that one (L) wire in order for my alternator to function properly. Than why does OEM Corvette harness use three if all you need is one?
3) If I unplug alternator plug all together, the annoying dummy light turns off of course, but it does not affect alternator operation. With or without the plug, the alternator does what it wants to. Some days it charges at 14.5V, and others it will drop to 13.2V (regardless of how much load I put on my charging system). But I am reading that apparently C5 alternator is adjusting to whatever the ECU is telling it charge at.. So 13V can actually be normal on a C5.
This is my first GM engine swap experience so I am hoping someone can shed some light on my "problem".
Thanks in advance!!
Thanks in advance!!
I can probably answer this for you, but I have to look at my truck. I promise, I will try to remember this, but if I don't answer in 2 days at most, feel free to pm me, and post a link to this, and then I will remember. I can explain what wires go where to get the dummy light off, and I don't know about the 13v deal, but I DO have a charging issue with my lights and stereo on at night. I think my gauge hits 11.5-12v, something I need to correct 1 way or another.
Thanks.
Was anything found about this? I'm having the same issue with voltage not staying constant, even when I remove the PCM from the equation and put 12 volts straight to "Generator Turn On Signal". I also noticed it acts the same even if unplugged (as the original poster said his was doing).
Internally the "L" pin is a ground with the alternator "off", this allows the lamp to light. When the alternator spins up, the the "L" terminal produces voltage which turns off the lamp by virtue of 12v -> 12v (no ground), thus no current flow. If you wire it direct to full hot, you'll kill the battery PDQ.
https://www.summitracing.com/parts/p...FQKBaQodosgBSA
I used this connector from painless and connected it to key on power.
i'm confused so wire goes to resister then to light for grounding
sorry little ignorant here
