What Trany to run with ly6
Old 05-28-2016, 04:09 AM
jnitecrawler's Avatar
Default What Trany to run with ly6
Hi, I want to do a ly6 swap to my 1998 crew cab 3/4 ton 4x4 with 5.7 l got a used 09 ly6 with factory harness for free. I bought a crane cam 199/199for $100. I want to make the stand alone harness my self. The question is do I use the 4l80 that is in the truck and have to buy a controller for it. Or should I pick up a 6l90? The harness I have is for a 6l90, I think this would be easier swap wiring wise. I will be using the truck as a daily driver and for towing my holiday trailer. Thanks.
Old 05-28-2016, 07:01 AM
alocker's Avatar
The biggest issue with the 6l80/90 is they are huge. Since space is less of a concern in a truck I would go withheld 6 speed all day long.
Old 05-28-2016, 07:38 AM
casias's Avatar
I would second the 6l80/90. You shouldn't have any trouble fitting it in. At most, you may have to open up the tunnel a little bit near the back.
Just make sure you get a transmission that is the same year, so you don't have trouble with the TCM not wanting to talk to the ECU. There was a change in those years (I think around 2008).
I have the 6l90 in my Dakota. It fit in that with only a small amount of pushing the tunnel, and has been a great transmission.
Old 05-28-2016, 10:27 AM
Jimbo1367's Avatar
The extra low 1st gear will aid getting the heavy truck going too.
Old 12-06-2017, 05:00 PM
Jeremy101's Avatar
Will any 4l60e 2wd fit a 2007 ly6 ?
Old 12-07-2017, 06:23 AM
Restricted User
JoeNova's Avatar
Basically any Chevrolet V8 transmission will technically fit. The bellhousing bolt pattern has almost never changed.
Old 12-07-2017, 06:49 AM
67Skylark's Avatar
GM put the 4L80 behind the LY6 so it will work.
Old 12-07-2017, 04:43 PM
Jeremy101's Avatar
Default Ly6
The only reason I'm wanting a 4l60 is the size is smaller so I won't need to cut my tunnel up. Thanks for the reply
Quick Reply: What Trany to run with ly6
