A body T56 clutch pedal travel
Curious as to where people are putting bumpers to prevent having too much pedal travel. I'm not really sure how to know how much travel I need or where to weld in a stopper. I've seen it mentioned in threads in passing but was hoping someone might have pictures of what exactly they did and how they determined where.
Thanks in advance
Thanks in advance
Every setup is a little different, but once everything is installed you'll be able to push the clutch pedal until it stops. Have someone take a measurement from the arm of the clutch pedal to the closest spot on the floor. You can weld a threaded tube or deep threaded nut to the arm. I have used a hood stop bolt with the bumper and just adjust it so the pedal stops just a tad before the clutch stroke bottoms out. I have also seen an adjustable stop installed on the floor. I just didnt want mine visible so I put it on the pedal.
Seems easy enough, thanks for the input. So assuming I use at least a basic amount of common sense, when pushing it down all the way to determine the travel there isn't any risk in going to far and blowing a seal or gasket or anything? I have an extra master sitting around, but I don't want to break anything during the dial-in phase.
Pedal Stop
I think I posted this info before. I used a hood bumper with a tab welded to the pedal. I just mock it up to find where the pedal arm would touch the floor board and marked and welded the tab for the stop.
You just need to make sure your Master has the correct travel.. just a hair short of 1"(if using a OEM 4th Gen Master).
What I did for the tab for the master rod, I mounted the pedals up, used a vise grip to hold the tab in placed. Then moved the tab around until I got the correct travel by re-clamping the tab and vise grip. Once it was good, I took it out and welded it in place.
BC
BC
Cool, thanks for the pics, I haven't welded anything yet but think I can handle that. Hood bumpers seem to be the way to go, I'm willing to bet I have a couple in the garage already.
At the time I was buying parts I didn't have a welder, so I bought the McLeod pedal that already has the tab in the right place.
Did anyone add a switch of any sort to make the pcm think you're in neutral? Or is that a thing to worry about? I guess in switching from auto to manual I'm not sure how the computer knows the car is in neutral so it will start.
I was thinking maybe a starter relay ground switch on the pedal, what did you guys do about this?
I did wire up the reverse lockout, back-up lights, and vehicle speed sensor.
Everything works fine.
I would definitely wire in a NSS, we all know that we sometimes get into a rush and try and start a manual car while it is in gear, and then remember to push in the clutch pedal after it wouldn't crank over, if you have driven manual cars long enough you have or eventually make that mistake and about **** your pants if it starts due to a bypassed or non-existent NSS and lurches forward and hopefully doesn't go through a garage door or hit someone before you can hit the brake.
With that said my 69 chevelle 4 speed came factory with a NSS mounted to the clutch pedal all it does is interrupt the large purple wire that is the starter signal wire that goes to the starter solenoid. I ordered another switch from one of the parts houses and adapted it to the pedal on my 1966 GTO. You don't want to take short cuts with safety items like a NSS.
It only takes one accident and somebody getting seriously hurt to make you change your opinion on safety related items. I know whenever I park my manual car I always leave it in either 1st gear or reverse gear and usually with the park brake applied, but not always if I'm on a level surface, so starting a car with a manual transmission in gear without a NSS it will definitely jump forward, if you have been driving a manual car for that long I find it hard to believe you've never tried to start it and remembered you had to push in the clutch pedal to start the engine, if it was equipped with a NSS. On the flip side if you have been driving a manual car that long without a NSS that you've never tried to start it accidentally while it was in gear and have the car lurch forward?
After thinking about it a bit I might just add a simple toggle switch for the NSS and use one of these delay timers for the reverse lock out. The camaro console has a traction control button that looks like it could be repurposed fairly easily.
http://www.ebay.com/itm/Cycling-Dela...YAAOSwnipWXkx8
What this does around the 11:30 mark is sort of what I was thinking, push the button and have X number of seconds to put the car into reverse.
www.youtube.com/watch?v=GXCvPdCEKOM Multi-functional Timer trigger configuration - YouTube
If your harness still has the pin out and sensor for reverse lockout, the PCM should energize the lockout solenoid when the speed is below like 2 or 3 mph I think. It reads this from the VSS, as I understand it.
I just plugged mine in and it worked fine. It's a nice feature to have functional.
