Vintage Air
Vintage Air
Have a 72' Chevelle SS with a 5.3 Vortec swap. Like to know if anyone has added Vintage Air to this type of swap and if so, were there problems? I know the original a/c compressor was a 4v belt drive and not sure if the Vintage compressor is the same. Also does someone make a bracket that will work with the stock truck pulley system?
Thanks
Bob
Thanks
Bob
I was looking at the vintage air sight they had a bracket to fit their Vintage air pump bracket#141810
gm truck ls compressor bracket lower mount center of crank to outer edge of compressor is 11 3/4"
and wants you to Use compressor 04709-vma. With it
