Drive shaft bolts continued
Old 07-07-2016, 05:23 PM
AB6DO's Avatar
Default Drive shaft bolts continued
Trouble fitting the drive shaft bolts into the pinion flange on the 1999 Ford Explorer pinion flange. I got the bolts from the local dealer (12mm 25 1.75 thread) 12.9 stamped into the head of the bolt..
Bolt will only go in about a turn. Ford parts guy said this flange bolt size was used on all Ford 8.8 rear ends. 7/16 coarse SAE bolt will thread in but is a sloppy fit.
Thinking about running a 12 mm tap thu the holes,
Old 07-08-2016, 04:55 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Be careful with the tap because it might screw up the threads. I believe they make special thread chasers that are designed to clean up the threads instead of cutting them, like a tap. I'd use one of those with a lot of anti-seize and see if that doesn't clean them good.
ANdrew
Old 07-08-2016, 07:08 PM
DW SD's Avatar
Sounds like you have the wrong pitch bolts. Dealer parts-guys make mistakes.
Old 07-09-2016, 09:17 PM
AB6DO's Avatar
Default Problem solved
Borrowed/rented 12mmx1.75 thread pitch chase tap from O'Riley's. Liberal anti seize and chase tap. Problem solved. Thanks for the help.
Old 07-09-2016, 09:20 PM
Glad it worked out! Sounds you just had some crap in the threads....
Andrew
Quick Reply: Drive shaft bolts continued
