Need some help with lq4 accessory kit
I've got an 06 lq4 that is going in a 70 c10 short wide that I'm also going to put a single turbo on. The accessories that came on the used motor were rusted out and trash. So I have nothing usable. I'm going to run an ls6 intake manifold, so the truck water pump can't be used.
I'm looking at this accessory drive kit:
https://www.summitracing.com/parts/nal-19257325
It states I'll need to run a different balancer (gm part number 12635649). I'm fine with that, as I have to take the truck balancer off anyways when I swap in a different cam. Which water pump should I run with this kit? I'm guessing just a standard fbody or corvette pump?
GM also has a separate kit with an a/c bracket that I can adapt on later to this accessory drive.
