Ls6 350z conversion
Ls6 350z conversion
Hello everyone finally my 350z conversion is coming along. Just fired her up for the first time but I still have ways to go until she's ready. Things that need to be done
-LSA blower
- LSA adapter plates and accessories
-Ac
-tach
- throttle cable
-upgraded fuel system for the supercharger
-after market radiator
I have a question for those who've done the conversion, which radiator and fan setup did you recommend? It looks there's Lil to no room and I still need to fit a ac condenser and heat exchanger.
-LSA blower
-Ac
-tach
- throttle cable
Here's the plan, I'm wanting to put on a LSA supercharger but I have cathedral heads. I know I need adapter plates to make it work. I'm using the f-body setup so what do I need to make this blower work?
-LSA blower
-Ac
-tach
- throttle cable
Not sure on ac, don't have it anymore
Throttle cable I just used a jegs cable and hooked it to my stock pedal (super easy to do) than $25 bracket for trh intake
Fuel system you will want to order the parts from CJ motorsports to mod you fuel bucket to be a return system, drop in a 340 pump or 2 . then whatever rails and reg. ( I run a magnafuel) you want
Tach I used a speedhut and instaleed in stock spot, super easy to hook up and works great!
Why not get square port heads? With what you are spending on the the blower itseems like a small expense to me.
