FEAD Not available Chev 19257325 Corvette Style Accessory Drive System
Old 10-20-2016, 06:32 PM
68conv455's Avatar
Default FEAD Not available Chev 19257325 Corvette Style Accessory Drive System
Anyone notice that this corvette accessory drive system is not available anywhere. It is backordered at GM. Anyone know the deal with this?
Where can I get a set-up?
Old 10-20-2016, 07:54 PM
slogo's Avatar
Will the holley stuff not work for you?https://www.holley.com/products/ls_p...essory_drives/
Old 10-20-2016, 09:23 PM
1964SS's Avatar
i second the holley fead system
Old 10-22-2016, 01:33 AM
1981TA's Avatar
Iirc, Chevy produces the kits in batches.
Old 10-24-2016, 08:47 PM
68conv455's Avatar
Trying to save a few bucks with the GM kit. The holley one is about 200 more
Old 10-25-2016, 11:24 AM
Jimbo1367's Avatar
While HOLLEYs is a nice kit, I'd prefer the GM. HOLLEY 's GEN. v LT version if the best I've seen.. I hope they do one for the LT4
Old 10-25-2016, 05:22 PM
1964SS's Avatar
I assumed you had accessories and just needed a bracket kit.
Do you already have a corvette spaced crank pulley?
Old 10-26-2016, 10:24 AM
jcvett56's Avatar
It's rumored that there is an issue with the power steering pump and/or reservoir. This is why the kit has been unavailable for a while. I don't even know if they have an ETA or if it's been resolved. Again, just rumored so I'll spread it some more!
Old 10-26-2016, 08:35 PM
68conv455's Avatar
I don't have the PS pump, alternator, or brackets. The complete kit would work perfectly for me.
Engine is a new crate LS376/430 with correct water pump and crank pulley.
Old 10-26-2016, 10:17 PM
gjestico's Avatar
The main bracket is cheap. Like $70 on ebay new. Is the PS pump the same as the Camaro unit ?
Old 10-28-2016, 12:50 PM
Hart_Rod's Avatar
What's the price of the GM kit?
Old 10-28-2016, 06:09 PM
68conv455's Avatar
About $580
Kit Includes:
Qty 1 Part #12555222 - Bracket Power Steering Fluid Reservoir
Qty 1 Part #12578067 - Bracket Generator and Power Steering Pump
Qty 1 Part #25888970 - Generator
Qty 1 Part #15261472 - Pump Power Steering
Qty 1 Part #12568997 - Pulley Power Steering Pump
Qty 1 Part #12555693 - Brace Power Steering Pump Front
Qty 1 Part #15907878 - Hose Power Steering Fluid Reservoir With Clamps
Qty 1 Part #26046502 - Reservoir Power Steering Fluid
Qty 1 Part #10317982 - Cap-Power Steering Fluid Reservoir
Qty 1 Part #12569301 - Tensioner Drive Belt
Qty 1 Part #12568996 - Pulley Belt Idler
Qty 1 Part #12579229 - Belt Water Pump/Generator/Power Steering Pump
Qty 2 Part #11515768 - Bolt-10x1.5x40MM- 15MM Drive
Qty 1 Part #11526714 - Bolt-10x1.5x110MM- 15MM Drive
Qty 1 Part #12552922 - Bolt-10x1.5x160MM- 15MM Drive
Qty 3 Part #11516357 - Bolt-10x1.5x75MM- 15MM Drive
Qty 1 Part #11518631 - Bolt-10x1.5x65MM- 15MM Drive
Qty 2 Part #24503609 - Bolt-10x1.5x95MM- 15MM Drive
Qty 2 Part #11515758 - Bolt-8x1.25x30MM- 12MM Drive
Qty 2 Part #11516697 - Bolt-8x1.25x85MM- 13MM Drive
Old 10-28-2016, 06:33 PM
LLLosingit's Avatar
I'll do some searching, GM performance offers some modified kits that might work for you. When I bought my kit for my LSA blower swap I found a kit that moved things around to clear the steering box on older model swaps, They may have something like that in the corvette spaced fead.
Old 10-28-2016, 06:42 PM
LLLosingit's Avatar
http://www.jegs.com/i/Chevrolet-Perf...55067/10002/-1
Old 10-28-2016, 06:43 PM
LLLosingit's Avatar
Here is a link to all that FEADs Jegs carrieshttp://www.jegs.com/p/Chevrolet-Perf...06347/10002/-1
Old 12-24-2016, 12:30 PM
68conv455's Avatar
Update on the corvette style FEAD with p/s no AC.
- GM unit is back-ordered with not date available.
- Holley unit is back-ordered with a Jan date for availability (although this date keeps getting pushed back). I have one on order since Thanksgiving so I know.
Old 12-24-2016, 07:47 PM
01cherryreds10's Avatar
https://m.summitracing.com/parts/hly-20-135?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-holley&gclid=CjwKEAiA1vjCBRDd-9q3w4OF6WUSJACWv_sVHL06o8CzToHEkpU2zDDUJrjqN8iWHh6 pJk_h_i_U8hoC0arw_wcB
Not sure where you ordered from but summit shows in stock to be shipped Tuesday.
https://m.summitracing.com/parts/hly-21-1?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-holley&gclid=CjwKEAiA1vjCBRDd-9q3w4OF6WUSJACWv_sVxGNHqCL5Sw31SuDcWelTs0Wnh-lBRfh0TsCM2XwktBoCHBbw_wcB
Also show the Corvette spacers in stock.
Sorry my links won't work on my phone for some reason. But I would have to say you can buy the holley brackets, spacers, and piece all the accessories together for cheaper than the complete setups from either holley or gm
Old 12-25-2016, 08:12 AM
68conv455's Avatar
I ordered it from summit. Summit tells me it will ultimately ship direct from Holley.
I've learned that you cant trust the websites for accurate info. Jegs did the same thing to me when I first purchased the GM kit. Their web site was corrected to show no ETA.
Old 01-18-2017, 06:30 PM
68conv455's Avatar
Still not available from GM or Holley
Old 01-19-2017, 05:35 PM
LLLosingit's Avatar
What Holley FEAD are you looking for? I have two of the same sets I bought a while back for a couple projects that got pushed to the side. I have this part number for the AC side Holley 20-142 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 , I'll to see what the part number is for the alternator and power steering side, I do know that it doesn't come with the pump or alternator though.
Quick Reply: FEAD Not available Chev 19257325 Corvette Style Accessory Drive System
