schematic help please
Thank you, you're absolutely correct. The IP schematic does show that. I was looking at the engine control circuits. The 05 harness I used on the first one I did had it in the engine controls and the ECM would shut the fuel pump down after a few seconds if it didn't see oil pressure.
I'm learning more and more as I do each one. Thanks again!
