Outlaw 996 Porsche build
I cut the sides off the bigger bottom one moved the engine to the front a few inches and welded it back.
The top one I had to move the two bolt holes on the mount just a little. Lucklily there are already two extra threaded holes in the floor in just the right spot.
I will get better pics when i get it on the lift again.
Whiteout ,Thanks I read over your build many times! Great to have you here!
DCD, the insulation on the top i did leave because its so thin it wont make any difference.
The insulation on the front end i did remove for the access hole.
Here is a pic of the top trans mount to show about how far it moved.
The other holes are just slightly closer together.
Great to see that you moved the engine back!!! I was going to do that, but you have to machine the bottom off the Kennedy adapter to clear the rear suspension cross bar. I will look at doing it if I switch over to the G96.50 transaxle. The adapter plate is way thinner.
Nah i will just make a new crossmember , maybe use just the ends of the stock one with a new center.
One hang up on moving it this far is the counter weight on the trans will hit the floor.....ooopppsss! No big deal i will cut it off ,some say it is good some say bad....i guess i will find out the hard way.
#32
Yeah one of the shift levers has a weight on top and the bottom. I removed the top one and the shifter works nice, I only hope it will work as good under power.
Pics asap........
Pics asap........
#33
Well it does not look like much but it took me almost 2 days of screwing with making this little bracket!!!
50gpm electric pump
Only took about 15 min to mount the thing.....
50gpm electric pump
#35
#37
Thanks guys, we will see but at this point the top of the hose fitting is no higher than the full level on the expansion tank. Could possibly be a little air at the top when full but that could be bled off.
#39
Pump should be ok as long as there is water on both sides -which there should be since expansion tank is highest point in the system .There does need to be a bleed hole in thermostat .I have a similar configuration and it works ok .
