Speed Engineering Fox swap headers?
Old 01-09-2017, 09:26 PM
TxFireman1972's Avatar
Default Speed Engineering Fox swap headers?
Anyone running the Speed Engineering Mustang LS swap headers? Thinking about ordering a set, but was wanting to see if anyone is running them already.
http://www.speed-engineering.com/fox...d-mustang.html
Old 01-09-2017, 09:59 PM
Lsxnafox's Avatar
I used them on my build they worked great, I'll post some pictures shortly.
Old 01-09-2017, 10:15 PM
Lsxnafox's Avatar
Sorry hard to really see anything but they went on fairly easy with no modifications to anything. I made my own steering shaft for my manual rack. I don't think one with the rag joint would fit between the tubes but I may be wrong.
The following users liked this post:
Gbodypoo (11-14-2022)
Old 01-09-2017, 10:36 PM
Looks good. I'm running a Maximum Motorsports steering shaft, so no rag joint problems lol
Old 01-09-2017, 10:40 PM
Lsxnafox's Avatar
Perfect!!! Your good then. Also, if your using a conversion harness the o2 sensor harness will reach. No extensions required.
Old 01-09-2017, 11:01 PM
Holley EFI, single wideband sensor, plenty long to reach!
Old 01-10-2017, 10:58 AM
Anyone else running these headers?
Old 01-10-2017, 10:56 PM
More specifically is anyone running them with a manual transmission?
Old 01-22-2017, 07:18 PM
I went ahead and ordered a set. They will be here this week.
Old 01-22-2017, 07:23 PM
Lsxnafox's Avatar
Here's a shot of how they exit the bottom. I think you'll like them.
Old 01-22-2017, 07:31 PM
Looks good. I'm looking forward to getting them put on so I can drive the car!
Old 01-22-2017, 07:58 PM
64post's Avatar
They appear to hang a bit low but the price is right. Dynatechs are double the money and don't have 02 bungs but fit well.
Old 01-23-2017, 09:14 AM
Last02TransAm's Avatar
I run some on my notch. I got a Team Z k-member though instead of AJE, but they still fit. Had to hit the bottom of the car with a BFH cause it hit right at the exit end of the header on the drivers side but they went. Can't beat it for the $$
Old 01-23-2017, 10:38 AM
Lsxnafox's Avatar
I don't think they could be any higher. The collecter is in line with the rest of the exhaust which runs really close to the floor of the car.
Old 01-26-2017, 12:30 PM
64post's Avatar
Just looks like a lot of room between 3" pipe and floor, could just be in the pic. Box 3
Old 04-25-2017, 03:03 PM
cbunn's Avatar
Do they make them in a 2"- 3.5 for 89 Fox?
Old 04-26-2017, 07:28 AM
learning91's Avatar
i have a set on my notch. they fit great! i have the Aje k-member and rear crossmember..one thing to note...if you are using the stock mount location for rear crossmember and a th400, on d.s. side..there was no-way i could get my pipe to come straight back as i see in the pics...i had to use an x-pipe to turn away from the mount and its still tight.. that is with 3" x-pipe...i will try to get some pics...i havent finished the rest of the x-pipe for other reasons but the front is done and it all seems to fit nice and tight to floor...those headers are nice pieces especially for the money
Old 04-26-2017, 07:45 AM
cbunn's Avatar
Default 2" Speed Eng. headers
Do you have a part # and where did you buy them at?.I'll be using motor plate with a glide and bullet type mufflers!
Old 04-26-2017, 09:42 PM
learning91's Avatar
i dont have a part number , just search on ebay..ez to find @ 299.00
Old 07-08-2017, 08:47 AM
STOCKLSPAPA's Avatar
got any pictures of this? I'm about to buy a set but I want to make sure they fit good with a th400 before pulling the trigger
Quick Reply: Speed Engineering Fox swap headers?
