70 camaro lsa install help
Good evening
new to site. Have a 70 camaro, stock powder coated front frame tied into a set of competition eng frame rails with dse mini tubs that have 2 extra inches added to them and a 9 in rear. I have just purchased a lsa motor out of a 2013 zl1 camaro that has lingenfelter heads crank pulley, and a kenne bell 3.2 supercharger. the a/c mount is down low on passenger side and the alt is low on drivers side.
Anyone have any help with this set up as to what mounts or kit to use and are there any issues on the low mount ac and alt ? Thanks in advance. or even a good company that I can get info from on this build.
Go 98-02 Fbody pan (entire pan kit through www.paceperfprmance.com is cheaper than the Holley pan.) 1" setback swap plates, Dougs LS swap headers.
Holley mounts
I would use the Holley mounts, pan, and exhaust. Save yourself the headache. The engine will sit nice and low, and have the correct driveline angles. If u go with the brp mounts, pick yourself out a nice big hood scoop. You will need it.
IF $ isn't a huge issue, deff. go HOLLEY. Real nice system.
