What value of fuses go here?
Here is a copy of my wiring schematic - can someone advise me on the following:
1) What value of fuses should I use for 1-4 and 7 (the cigarette lighter socket is powering a radar detector?
2) Do I need to fuse the supply to pins 86 of the fan relays?
3) Are the injectors wired correctly, or should I put the O2 heaters on a separate fuse?
The injectors are 15A fuses, one for each bank. This fuse also supplies power to the coil packs. I wouldn't run my heaters off of the injectors and coils. I relayed them so they would turn on wiith the ignition
Fuel pump fuse is 20A
PCM to Battery is 10A
Heaters are 20A
PCM 'hot in run' is 15A
I'm not sure on the fans, but I thought I read somewhere that the PCM grounds the relay, not powers the relay to turn the fans on.
I'd do a search on 'fan relay' and check. My fans are always on so I've never checked. My schematic just show it going to the 'cooling fan system'
PED
Heaters are 20A
PED
