oil pressure wire
Old 11-30-2004, 01:15 PM
flippincamaro's Avatar
Default oil pressure wire
Can i run a aftermarket gauge to my factory oil sending unit wire that tells the oil pressure to the computer? thanks kenny
Old 11-30-2004, 02:53 PM
Scooter70's Avatar
You're better off putting in the sending unit for the gauge so that they are calibrated together. (The F-body LS1 doesn't have an oil pressure sender in it at all.)
-Matt
Edit: I must have been sleeping when I wrote this.... I was thinking of the oil temp. They all have pressure senders.)
Old 11-30-2004, 03:40 PM
MrDude_1's Avatar
umm, my understanding is this:
the 98 Fbody had a oil pressure sending unit.
if you put a 98 sending unit in it, you can use that signal for the GM oil pressure gauge... and it matches the signal needed for my 91 camaro... i donno about your swap, but its GM, so its probly the same.
Old 11-30-2004, 04:45 PM
Mine has a one wire connector 2001 model I cant just splice into it to make my oil pressure gauge work for my aftermarket gauge
Old 11-30-2004, 05:20 PM
patrick_rodgers's Avatar
Just above the oil filter there is an aluminum cover (say 1.5" x 5/8"), that might have an untapped boss. You can put the sender there since that is part of the oiling system. The replacement Camaro part I bought did not have this boss. The Corvette ones are apparently tapped for a sender.
Old 11-30-2004, 07:47 PM
crainholio's Avatar
I used an '01 engine and harness, and connected its oil pressure gauge wire to my '82 instrument cluster oil pressure gauge. It indicates slightly lower than reality but consistent, checked against a mechanical capillary-tube gauge.
The '82 instrument isn't calibrated for the same resistance range as the '01 pressure sending unit, but it gets the job done. If I see the dash gauge go below 45psi, I know I have problems.
So...it won't likely hurt to try connecting the '01 sender to your aftermarket gauge, but I'd strongly recommend checking it against a known-accurate sender and gauge. I scrounged an extra plate as mentioned above, drilled & tapped for a 1/8" NPT fitting, and threaded in the old capillary tube gauge just to get readings. When done, I swapped the plate out (you could just thread a 1/8" plug in there).
Old 11-30-2004, 07:55 PM
Thanks alot that helped I will try it tomorrow since it is raining here
Old 11-30-2004, 09:56 PM
Red Heartbeat's Avatar
Tap the boss that bolts on above the oil filter with a 1/8" NPT tap and install the factory oil sending unit in the tapped hole.
Old 11-30-2004, 09:58 PM
Scooter70's Avatar
Which aftermarket gauge did you get? My Autometer one came with the sender. I put it in the tapped boss above the oil filter (as described above by Patrick_Rodgers) and plugged the stock pressure sender hole since the new sender wouldn't clear the intake.
Old 11-30-2004, 10:50 PM
it is made into my tach by phantom some off brand that is four in one looks good
Old 12-01-2004, 09:50 PM
hooked it up to the sending unit and my gauge works now reads about 30-45 psi at idle
thanks for all the help crainholio
Quick Reply: oil pressure wire
