6.0L Conversion: TKO vs T56
Old 12-03-2004, 02:17 PM
68driver's Avatar
Default 6.0L Conversion: TKO vs T56
I'm considering a 6.0L truck motor with an LS1 intake swap for my 68 camaro. Transmission conversion kits are available for my car in both the TKO 5-speed and T56 6-speeds that align to the original console shifter. The TKO is about $1000 cheaper.
Three questions:
1. Will both transmissions mount to the 6.0L without issues?
2. Is the T56 worth the extra money?
3. I still might consider an automatic... any advise on manual vs. auto?
I'll be using my car primarily for car shows and cruising, with an occasional trip to the drag strip.
Old 12-03-2004, 02:57 PM
Chris @ Speed Inc.'s Avatar
check out www.gforcetransmissions.com they rock!
Old 12-03-2004, 03:11 PM
Scooter70's Avatar
http://www.gforcetransmissions.com/tran_t-56_price.asp
I like the stock F-body T56 with 3.70 rear gears in my conversion. If you aren't going to beat on the car all the time, I don't think there's a need for a $5k "bulletproof" tranny.
Old 12-03-2004, 04:44 PM
1bad57's Avatar
Three questions:
The t56 is made to mount up to the 6.0 as the 6.0 is a ls1, it will also mount to the 4.8; 5.3 they are pretty much universal. The t-56 is extremely strong and rugged by itself without any add ons or should i say add ins. They are plentiful and an all around great transmission. if you want to go the 6 speed route. I gave $900.00 for mine with shifter and bell housing. of course i added some other stuff, and then about another $500 for flywheel clutch package. Havn't heard anything good or bad about the TKO so can't help ya there, but i'm more than pleased with my T-56
Old 12-04-2004, 02:11 AM
red90cobra's Avatar
Go with the T-56 its worth it
Quick Reply: 6.0L Conversion: TKO vs T56
