Whats the best route?? Need info please!!
I am currently building an 2000 LS1 for an offroad application (short track, trophy truck, prerunner). I dont have the cam and heads yet, but pretty much know what I am getting (LS6 intake, PRC 2.5 heads, TSP 235/240 .603/.609 113, headers, custom intake with K&N, underdrive pulley, LS6 oil pump, bla, bla, bla). My question is tuning the stock pcm to work in my application. I will want to delete the following programs and then some from the pcm: EGR, ABS, MAF, SMOG PUMP, INSTRUMENT PANEL, HVAC, ETC, ETC. To sum it up, I want the bare min for the motor to perform (CRANK SENSOR, CAM SENSOR, KNOCK SENSORS). Where do I start? Any opinions? Thanks, Joey
hvac,IPC,ABS are not controlled by pcm
to delete the codes pertaining to maf/egr/fuel tank sending unit/rear o'2s/smog pump/bla bla bla
you need hp tuners or flashscan
they just turn on the check engine light, except the maf you would run SD without it
You would have to get one of those "Off Board Programming Harnesses" Speartech sells.
http://www.speartech.com/compreprog.html
