Gauge swap
Old 07-06-2005, 06:37 PM
CONVERTED's Avatar
Default Gauge swap
I'd like to upgrade my 95 gauges to the 97+ gauges has one done this or know what is required too do so?
Old 07-06-2005, 08:03 PM
ilovefirstgens's Avatar
If you need the gauges and housing i have some out of a 99 ss for sale, they also have a white faced insert with carbon fiber trim.
Old 07-06-2005, 08:20 PM
TJ
TJ's Avatar
the 99 gauges wont be a direct swap for you. if you get a 97 model year gauge cluster, you should be fine. only downside is the low oil light will remain on, and it will NOT go off. in some cases the ABS INOP light comes on, but thats a simple fix if you dont have ABS, just install a 40ohm resister to the cluster wire.
i put the 97 gauges in my 88 iroc, there was a lil more involved in the 98+ gauges. 97 gauges look the same, just get one with the digital odometer, they look much better.
Old 07-07-2005, 02:37 PM
CONVERTED's Avatar
thats great thank you so much.... I thought it was would be that easy but I was affraid of spending the money on a cluster I couldnt' use without buying a new BCM or somethign else...
Old 07-07-2005, 09:59 PM
TJ
TJ's Avatar
the BCM SHOULD interchange. i havent heard any horror stories anyway. there is always a 1st.
good luck.
BTW. make sure you buy a V8 cluster if you have a v8..... etc.
Old 07-07-2005, 10:31 PM
joking511's Avatar
Will 97 up fit in 96 and under dash
Old 07-07-2005, 10:59 PM
TJ
TJ's Avatar
firebird dash, no chance on a camaro dash.
97-02 camaro and 93-02 firebird guages are interchangeable fitment wise.
93-96 camaro is its own ballgame.
Quick Reply: Gauge swap
