Conversion folks please list your conversion in here
Old 10-19-2016, 01:31 PM
  #1621
BigGoom's Avatar
Default 95 Firebird Swap
1995 Pontiac Firebird
5.3L LM7 with auto trans TBD
5.3L LM7 from 2003 Silverado
Texas Speed 228R cam
862 heads cleaned up with BTR .660" lift dual platinum spring kit
GM F-body oil pan, pickup tube, and windage tray with GM oil filter
LS2 heavy duty timing chain and Chevrolet Performance oil pump
Old 10-25-2016, 08:25 AM
  #1622
SgtSkid's Avatar
1986 BMW 325 swapped with 2003 LM4 and T-56
Old 11-03-2016, 12:11 PM
  #1623
Hart_Rod's Avatar
1) 1969 Suburban
2) 5.3/A4/Magnacharger
3) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
Attached Thumbnails Conversion folks please list your conversion in here-20161024_171424_resized.jpg   Conversion folks please list your conversion in here-20161024_171408_resized.jpg   Conversion folks please list your conversion in here-20161024_171445_resized.jpg   Conversion folks please list your conversion in here-20161010_211052_resized.jpg   Conversion folks please list your conversion in here-img_2576.jpg
Conversion folks please list your conversion in here-img_2572.jpg   Conversion folks please list your conversion in here-img_3644.jpg   Conversion folks please list your conversion in here-20160929_193909_resized-copy.jpg
Old 11-03-2016, 08:49 PM
  #1624
C450's Avatar
Default 74 gmc
1974 GMC
Factory 2002 4.8 with TH400 and 3.73 gears with a welded diff.
Old 11-04-2016, 11:37 AM
  #1625
boostedc20's Avatar
Default 1965 C20 Flat Bed with a boosted 5.3
Old 11-06-2016, 12:37 PM
  #1626
68Catanlina707's Avatar
Project in progress
66 Buick LeSabre Custom 400 2dr HT
02 LM7 (Avalanche), 01 TA cam 196/208,stock ported/polished intake and TB
4L60E
Old 11-10-2016, 08:40 AM
  #1627
LSgrandcherokee's Avatar
Not that anyone cares but I feel like I wasted my time signing up I'm new at the performance LS and looking for information to help me and I have read threads about someone with a mustang sucking dick and someone else having buthole aids , I'm not sure if I can navigate around the all the teenage BS to find any information that I can use
But if anyone can help I am building a Mega truck using an 04 chevy truck 6.0L stroked (421 cid) the biggest CNC ported heads AFR offers.I don't know cam #s just it power range is 2500 to 7900 RPM Holly 300-123 intake with a 102mm throttle body 80 lb injectors , backing it with a turbo400 with a 5500 stall converter what I'm looking for someone in within the eastern seaboard that can help me out with tuning
Old 11-10-2016, 08:44 AM
  #1628
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Instead of looking for a tuner, buy yourself some grammar lessons.
Andrew
Old 11-11-2016, 06:01 PM
  #1629
TxFireman1972's Avatar
You are probably not going to get much help with a post like that
Old 12-07-2016, 01:25 PM
  #1630
ehjorten's Avatar
1991 Chevrolet V3500 - Gen. V TBI454, 4L80e, NP205, GM 14-bolt FF Rear, Dana 60 Front, 4.10:1, 8" Lift
In August of this year my 454 developed a slight rod-knock. I thought I would limp along for a bit while I figured what I was going to do, but it progressed pretty fast and by about 3 weeks was knocking pretty hard and I could feel the rough idle of the engine. So...I parked it before anything really bad happened!
I contemplated a Vortec 454, but a decent engine was hard to find that didn't need a lot of work, or was missing the top-end. I wanted to build an L21 engine out of one as I did not want to commit to the frame-rail surgery that was required to fit a 8.1L.
In my difficulty finding a Vortec 454 that was worth the money being asked, I started looking at LS engines and what it would cost to go that route.
Fast forward to a couple of weeks ago and I am now the owner of a 6.0l LQ4 out of a 2004 GMC Yukon XL 2500 with 95k on the odometer. I got the engine from a real class-act recycler that disconnects everything at the connections, caps open lines and just does a proper job of dropping-out an engine. I got a full drop-out with PCM, wiring harness and even the Yukon Power Distribution Box!
I have a few questions here: https://ls1tech.com/forums/conversio...0-6-0l-ls.html
and I am sure I will have more!
Old 12-11-2016, 07:24 PM
  #1631
9mil's Avatar
1) 1988 Lotus Esprit Turbo
2) 5.3 currently NA
3)Audi 01X 6spd manual
https://ls1tech.com/forums/conversio...wap-intro.html
Old 12-19-2016, 04:40 AM
  #1632
PharmD2B31's Avatar
Default 2005 Jeep LJ
2005 Jeep LJ
Here is the current plan:
~2007 Corvette LS2 Engine (Stock)
~Monster Transmissions 4L80e tranny w/ 1800 stall converter
~TCI 4L80e Flexplate
~Summit Racing Aluminum Flexplate Dust Cover
~Altas 3.8 4 speed Transfer Case
~Custom Standalone Harness from Hotwire Auto w/ TCI Transmission
Controller built all into one harness
~Removing the stock Jeep PCM & TCM
~Dave's Unlimited Motor Mounts
~Sanden A/C Compressor
~Flex-a-Lite Radiator w/ Electric Fan
~PSC Power Steering Pump
~PSC Alternator/Power Steering Relocation Bracket
~Novak A/C Relocation Bracket
~Stock Jeep LJ Fuel pump w/ Novak LS pump upgrade kit
~Aeromotive Fuel Pressure Regulator
~Stock LS2 Exhaust MAnifolds
~Borla Exhaust 2 into 1
Old 12-21-2016, 12:17 PM
  #1633
Timbo67's Avatar
1967 Chevrolet Biscayne
426.4 LS3
200R4 / Circle D TQ Conv.
David Cook Carbureted!
Old 12-24-2016, 07:15 AM
  #1634
Romulus22's Avatar
1985 Chevrolet Chevette. 2100 lb curb weight
346" LS1, Powerglide, Ford 9" 35spline/spool/3:00 gear
Old 12-24-2016, 12:38 PM
  #1635
PhilMorrison's Avatar
Hi, I thought I'd re-introduce myself as I think my original thread about getting ripped off by Thunder Racing some years ago has been archived.
I'm from the U.K and own a company called Driftworks, we have an old Toyota Corolla AE86 that's had a lot of work done to become the DW86.
The build always had an LS, but we've gone through a few revisions, and we're currently rebuilding our RHS LSX454 with RHS 307cc heads, Mamo Motorsports valve train, Dailey dry sump, Jenvey throttle bodies.
The car is currently 1120kg (2470lb) which is very heavy for an 86, but then as well as the big engine, it has a huge Winters/Howe axle, Quaife sequential box, and a lot of T45 re-inforcement.
Videos of the car in action:
A test session outside the workshop
Incar at Silverstone verses a very quick car.
Old 01-03-2017, 12:12 PM
  #1636
sportscitycyclery's Avatar
Default pulling out 5.3/ putting in 6.2 LS3
1) 07 chevy suburban
2)2016 6.2 LS3
My question's are should I use 6.2 LS3 balancer and water pump? Do I need to purchase power steering pump and alternator bracket for 6.2?
I have installed the 5.3l balancer and water pump on the 6.2 and having problems with 5.3 power steering and alternator bracket.(clearance issues)
much help would be obliged.
Old 01-03-2017, 07:48 PM
  #1637
Ely$78's Avatar
How do you conversion over the brake system on rolls Royce?
Please reply!
Ely
Old 01-03-2017, 08:35 PM
  #1638
Mercier's Avatar
346 LS1, 4L60E, Ford 9" 35spline/spool/3:00 gear
In one word:
Fantastic.
Carry on.
Old 01-11-2017, 10:18 PM
  #1639
LSxDatsunZ's Avatar
1978 Datsun 280Z
Garage rebuild LM4 5.3 with LS6 intake manifold (Random upgrades throughout the block)
Tremec T56 Magnum
Completely restored chasis
Hopefully have her on the road by spring.
Old 01-11-2017, 10:48 PM
  #1640
Mercier's Avatar
TRYING to keep from swapping this one until I get a couple others complete.. We all know it will happen... 85 K10 65K original miles, no recorded accidents, fully stock interior with everything working including analog clock and old crackly radio. 383 SBC, 700R4, light stall, 4.10s, Auburn lockers, etc. Haven't found a spot of rust even underneath, no cracks in original dash.
​dash. New paint.
Current long-term thoughts: cheapie 6.0, LSA blower, 4L80. The idiot in me wants to say 4x4 T56 but past a certain weight sticks aren't quite as much fun. Who knows.
Quick Reply: Conversion folks please list your conversion in here
