LS1 into 37 Ford "What is needed!" - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 02-05-2006, 08:55 PM   #1
Default LS1 into 37 Ford "What is needed!"
I just remove the engine and tranny from a 2000 Firebird Formula. This will be my donner engine for the 37 Ford. Will I have to change the front brackets and pulleys? What about the cooling issues, headers,wiring,motor mounts? What should I do to the engine and trans. before installing? I am new to this and I am a big fan of learning from others rather than the school of hard knocks! Any help would be appreciated! I am trying to have this car done by Goodguys this summer! PLEASE HELP! What comes first!
LS37 Ford is offline   Reply With Quote
Old 02-06-2006, 09:32 AM   #2
You may want to check out the FAQ sticky post at the top of the forum.
A forum member "Oscar Will" has a 35 ford with a LS1 and made this post in the FAQ: "You people with old car hybrids and straight frame rails can use the Corvette cast aluminum motor mount brackets with the stock oil-filled mount cushions. The cost is not ridiculous and the set-up works very well."
Also, S&P http://www.hotrodlane.cc/ has a project section listing a '39.
Hope this helps.
Steve
55chevy is offline   Reply With Quote
Old 02-06-2006, 04:50 PM   #3
Hope you will post pics when it is done 1
RFERG43 is offline   Reply With Quote
Old 02-06-2006, 08:25 PM   #4
Thanks for the info. Where is the best place to get the Corvette mounts? Dealer? or is there some aftermarket cheaper?
Old 02-06-2006, 08:25 PM   #5
Sure thing! Can't wait!
Old 02-06-2006, 08:34 PM   #6
Quote:
ebay will be your friend for conversion parts
jimmyp is offline   Reply With Quote
Old 02-06-2006, 08:38 PM   #7
What years fit? Do you know part #s?
Old 02-07-2006, 07:48 PM   #8
Oscar Will's Avatar
Ok, here are your numbers;
2 engine mounts P/N 10284134 list price is $80 each
1 10260643 bracket $75
1 10260642 bracket $75
Oscar Will is offline   Reply With Quote
Old 02-07-2006, 07:50 PM   #9
Did you use this set up on your car?
Old 02-08-2006, 12:18 PM   #10
Oscar Will's Avatar
Yes, I Emailed a few photos to you.
Related Topics
Thread Thread Starter Forum Replies Last Post
New to LS World '37 LS Introductions & Greetings 2 02-21-2017 06:47 PM
1937 Ford LS2 Install kwhizz Conversions & Hybrids 549 09-13-2016 08:18 PM
LS1 Driveshaft to 9" Ford tennsmith Conversions & Hybrids 6 04-26-2012 02:07 AM
GTO Gauge Module ABS Fault kwhizz Conversions & Hybrids 2 01-05-2012 06:14 PM
37 Ford &99 LS1 Joe Conversions & Hybrids 1 10-01-2002 07:37 PM
Tags
10260642, 10284134, 32, bracket, conversion, donner, f100, ford, gm, headers, ls, ls1, motor, mounts, oscar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
