fenderwell mounted pcm cover
Old 06-12-2006, 05:52 PM
Joe Nova's Avatar
Default fenderwell mounted pcm cover
I'm want to mount my pcm on the passenger side fenderwell of my 66 Nova. Does anyone know of a cover/mount made that will work and look good? It looks like alot of the pcm's are mounted inside of the cars, but my harness is not long enough plus with the vintage air added it will not have room under the dash. My ls1 is from a 2001 z28
Old 06-12-2006, 06:40 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
I am not aware of any covers, but I lengthened my harness and mounted the PCM inside the car. Snip.....solder...solder...snip....solder...solder ...snip...solder....solder....X60....Sheesh!
Andrew
Old 06-12-2006, 09:36 PM
pt67camarols1's Avatar
I got a stock mount from a S10 I think and mounted it in fenderwell. It is water proof. Isn't it?
Old 06-12-2006, 09:52 PM
sawzall wielding director
G-Body's Avatar
It is water proof and the PCM is mounted in the engine compartment in most LSx vehicles. There is a cover on the 2001 Tahoe computer mount. I am not using it in my conversion (I like the bare computer, makes it look high tech ) . But I will put the cover on tomorrow and snap a pic and post it.
Old 06-12-2006, 10:14 PM
Schitzo's Avatar
Andrew
you my friend are a patient man.....I was going to do this but after modding my harness and rewiring my entire car, I was done soldering for a while.....
my pcm is in the engine bay. I made a plate onto which it sits
Old 06-12-2006, 10:18 PM
G-Body's Avatar
I don`t know, after a microbiology or pharmacotherapeutics exam sometimes I just want a mindnumbing task to help me forget about exams. Snip, strip, slide heat shrink tube on, twist, solder, shrink, repeat.
Old 06-13-2006, 05:36 PM
Joe Nova's Avatar
pt67 camorols1 Do you have a picture of your s10 cover? Do you know the year of the s10?
Old 06-13-2006, 08:59 PM
67RSCamaroVette's Avatar
i polished mine. looks real nice.
Old 06-13-2006, 10:57 PM
G-Body's Avatar
Heres some pictures of my 2001 tahoe PCM mount/cover
Attached Thumbnails fenderwell mounted pcm cover-computer-no-cover.jpg   fenderwell mounted pcm cover-computer-cover-1.jpg   fenderwell mounted pcm cover-computer-cover-2.jpg   fenderwell mounted pcm cover-computer-cover-3.jpg   fenderwell mounted pcm cover-cover-inside.jpg
Quick Reply: fenderwell mounted pcm cover
