are TAC modules interchangable?
9 Second Club/LS1TECH Sponsor
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-05 TAC module works with 03-05 truck TB and 03-05 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-05 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
The 90mm LS2 TB is unique and will work with the 03-05 PCM, but requires switching to the 01-02 TAC module. It also requires our adapter harness for $50.
__________________
www.speartech.com
www.speartech.com
The 03-05 truck pedal works.
__________________
www.speartech.com
www.speartech.com
That will work fine as long as it follows in the correct year breakdown described above.
__________________
www.speartech.com
www.speartech.com
