electric fans
electric fans
so i decided to get rid of my a/c rad, and measured what i can use on it, 15 1/2 X 32 1/2 X 2 1/4, so i was trying to find electric fans to fit in that as a pusher, but i cant really find anything to fit, maybe get a single e-fan to push and dual for the other side of the rad? any ideas?
any idea what the dimensions are?
The dual fans from a mid 90's Ford Contour/Mystique move as much air or more than the single Taurus one and fit the S10 rad perfectly. i have mine mounted as pullers but should not be a problem mounting as pushers as long as you are not using A/C. If the condenser is mounted space to the hood latch becomes a problem.
