TT Chevelle went to the drag strip. Update.
Old 10-01-2006, 04:30 PM
nitrorocket's Avatar
Default TT Chevelle went to the drag strip. Update.
I ran it Tuesday, but had some more problems. Good news is nothing broke, bad news is that I ran out of gear.
All runs were on 93 octane, and my cars has a 3850 lb raceweight. I made 2 passes with only 10 psi and went 10.80 @ 130 even on both passes. Went through the traps at about 6600 rpm.
I reset the boost up to 18 psi and ran out of gear, I had it set to 10 psi in 1st gear, 12 psi in second, and 18 psi in 3rd with the E-boost.
Due to a bad launch and having to pedal it the pass was pretty bad. I launched with a 1.90 60', my 1/8 mile was a 7.0@112, and my quarter was 10.55@ 138.
1.9 seconds before I tripped the clocks, I ran out of gear and was on the rev limiter at 7000 rpm till I let off right before I finished, hit the brakes just as I crossed the traps. The car sounded like it had gunshots coming out the tail pipes and was blowing flames out the tailpipes also! I luckily have it on video so I was able to time exactly when I first hit the rev limiter to when I actually finished the pass.
I was pretty dissapointed that I did not get to see how much power the car put to the ground by my trap speed.
I need to get some 3.08 gears for my 3 series carrier and some new tires. I have 3.42's now but did not count for converter efficiency. I also am trying new tires seeing that I has to try to keep the car straight the entire pass!
I hope the 3.08 gears are not weaker then my 3.42's, the ring gear is much thinner. I guess I will see.
Old 10-01-2006, 04:42 PM
69chevy's Avatar
sweet times. Looks like low 10's possible 9's are in the future. Not bad.
Old 10-01-2006, 09:25 PM
sawzall wielding director
G-Body's Avatar
Thats great for the first time out. A little taller gear and you should be able to hit low 10`s no problem. Can I borrow a a few HP next weekend? I need to cut about a second off my ET so I can outrun a Magnum SRT8 wagon. How tall of tires are you running, mabey you could just get a 30.5 or 31" tall tire instead of changing gears.
Old 10-01-2006, 09:51 PM
I run a 25" tall tire!
Old 10-01-2006, 10:20 PM
G-Body's Avatar
Well if you run a taller set of drag tires you could get away without changing the gear. If you run a 28" tire it would be equivalent to running a 3.08 gear, and a 31" tire would be equivalent to changing to a 2.73 gear. Plus a larger diameter tire puts more rubber on the ground when you launch .
Old 10-01-2006, 11:07 PM
Wnts2Go10O's Avatar
im gonn aagree with gbody and say just get some taller tires
Old 10-01-2006, 11:26 PM
THE_SUPRA's Avatar
nice! i like!
Old 10-02-2006, 08:28 AM
1bad4dr's Avatar
Impressive to say the least.... Looks like 9's are in your future once you get the gearing issue resolved....
Old 10-02-2006, 12:25 PM
gnx7's Avatar
Taller tires for sure.
That is a great mph for the octane that you are running!
This is the stock ECM with tuning I assume? Speed Density tune?
Old 10-02-2006, 12:45 PM
diognes56's Avatar
Nice runs :thumbup: .
David
Old 10-02-2006, 12:58 PM
c0ncEpT's Avatar
Nice times! Run a taller tire and solve your problem!
Old 10-02-2006, 01:54 PM
Cop Car's Avatar
i demand pictures with this thread
Old 10-02-2006, 02:46 PM
pist0lpete's Avatar
If you do a search you should be able to find some pics of his chevelle its pretty sweet.
Old 10-02-2006, 11:54 PM
350SS's Avatar
Damn, 138mph...that's movin
What kind of tires are you running at the track?
Old 10-03-2006, 03:11 PM
pist0lpete's Avatar
Hey nitro what fuel setup are you running? Modified stock tank or fuel cell etc.?
Old 10-03-2006, 03:40 PM
I run the stock tank with a sump, I run 315/35/17 drag radials, and I hpe to have a complete pass in a week or two with the new gears.
Old 10-03-2006, 08:09 PM
PRAY HRD's Avatar
nice mph nitro..........for those who do not know the car, it's not a drag car, it just has drag car power! lol. the 3.08's will give you better EPA and you can still keep your street car rims. i hope that they can hold up to 1000HP though!!!
Old 10-03-2006, 08:14 PM
nvmy2000ss's Avatar
Wow those are some good numbers. I dont think 9's are to far off.
Old 10-03-2006, 08:15 PM
nvmy2000ss's Avatar
Wow those are some good numbers. I dont think 9's are to far off. Good luck
Quick Reply: TT Chevelle went to the drag strip. Update.
