Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
Sign in using an external account
Register Forgot Password?
LSX Engines in Non-LSX Vehicles
Sponsored by
Don Hardy Race Cars
Thread Tools Search this Thread
Old 10-04-2006, 02:59 PM   #1
Garage is empty, add now
stealth71's Avatar
Trader Rating: 15
Default Fuel pressure regulator plumbing?
I just got an Aeromotive FPR and fuel rails. I will be running -8AN feed and -6AN return lines. My question is what is the best way to plumb the fuel rails and FPR?
I have seen it done a couple ways.
1) Feed line to FPR then out of FPR to fuel rail and capped at the end of the second fuel rail.
2) Feed line directly to Fuel rail, through second rail and then into the FPR.
Which one of these is better? Is there another option I am missing?
I would think having the FPR after the rail would keep the pressure more stable.
Here is my ghetto diagram:
__________________
Who cares about the paint, you won't see it long anyway.
'71 Chevelle - LS1/T56 swap - On the Street!!
stealth71 is offline   Reply With Quote
Old 10-04-2006, 03:20 PM   #2
Skele4door's Avatar
Trader Rating: 1
#2 is a better setup and is how mine is run except I've got -8 going both ways. It'll provide more stable fuel pressure especially if you plan to make a lot of power. BTW, if you want a nice place to mount yoru fuel pressure gauge aeroquip makes a nice 3/8" NPT to -8 fitting that has a 1/8" NPT port coming off the side so you can mount your gauge on the front of one of your fuel rails.
__________________
Chris Sanders
1991 GVR4 #57/2000
1993 RX7 LS1+T56 swap project
Skele4door is offline   Reply With Quote
Old 10-04-2006, 03:47 PM   #3
bczee's Avatar
Trader Rating: 12
One more good thing about option #2.. is the continues flow of gas through the fuel rail will also keep the fuel rail cooler resulting in a deleivery of a cooler charge of fuel. May get you a few extra..
__________________
71' Chevelle/Malibu - 99' LS1, LS6 Intake, Custom Cowl Induction CAI, Viper T56, 12 Bolt w/4.11 gears, Full Hotchkis TVS Suspension, Edelbrock Headers.
84' Z-28 350/T5
88' C4 Coupe L98/A4
71' Nova, Swap in Progress - LS1/4L60E , Full Hotchkis TVS Suspension
79' G-30 SWB 4X4 Van, 400cid / TH350 NP205
48' Ford F-1 1/2 Ton Truck, Stock 6cyc/3sp
bczee is online now   Reply With Quote
Old 10-04-2006, 04:11 PM   #4
LS1MCSS's Avatar
Trader Rating: 16
My system is hooked up like the first picture. My pressure seems to be pretty stable that way.
__________________
85 Monte Carlo SS, 5.3/4L60E Daily driver
84 Monte Carlo SS, LS3 418, 248/254 615/595 with XER and XE lobes. AFR 225, 1 7/8 Hedman headers from BRP. 200-4R. 9" Ford, 3:50 gears.
LS1MCSS is offline   Reply With Quote
Old 10-05-2006, 12:15 AM   #5
Trader Rating: 0
Don't forget the recommended way (from Aeromotive, anyway): pump is supplied via Y to both fuel rails, then both to the regulator, then return to the tank.
There have been several reports of this causing a slow rise in tank fuel temperature (due to engine heat being transported back to the tank via the fuel); eventually causing vapor lock. But this method is the best way to assure stable fuel pressure at the injectors.
jp
__________________
II Much Fabrication
parsonsj is offline   Reply With Quote
Old 10-05-2006, 01:10 AM   #6
red90cobra's Avatar
Trader Rating: 36
jp
what exactly vapor locks? i've had extremely high fuel temp but not sure of vapor lock?
red90cobra is offline   Reply With Quote
Old 10-05-2006, 08:07 AM   #7
Trader Rating: 0
Gasoline turns to vapor at around 130 degrees F. If your fuel gets that hot, it may disrupt the pump's action since it is designed to pump liquid, not vapor.
jp
__________________
II Much Fabrication
Old 10-05-2006, 11:54 AM   #8
Trader Rating: 0
I am not familiar with the Aeromotive FPR, but be careful. The option 2 requires a "return" regulator, which is very different from either a bypass regulator (option 1), or a traditional in-line supply type regulator. I'm sure if you follow the manufacturers recommendations, you will be fine.
Andy1
Andy1 is offline   Reply With Quote
Old 10-07-2006, 05:22 AM   #9
Trader Rating: 1
Aeromotive regs can be run both ways, the suggest option 2 is best but you can run them like option 1, mine is an aeromotive 13109 reg and I run it like picture 1, with constant 58psi supply.
GTS346 is offline   Reply With Quote
Old 10-08-2006, 11:11 AM   #10
ewingr's Avatar
Trader Rating: 0
How many lbs should the regulator be set at?
__________________
Thanks
Roger
http://www.shuttermaster.co
ewingr is offline   Reply With Quote
Old 10-09-2006, 10:11 AM   #11
jim57's Avatar
Trader Rating: 0
Default Vaporlock?
jp
How often does the gas in your tank reach 130 degrees? That is what the fuel pump is pumping. If the gas in the rail turns to vapor I would think that the injectors could handle that, in the old days carbs could not.
Jim
__________________
The males in my family mature much later!
57 Belair LS2/T56/Dana 44
2003 Harley FXD
2000 CLK430
jim57 is offline   Reply With Quote
Old 10-09-2006, 12:09 PM   #12
72ChevelleConv.LS1's Avatar
Trader Rating: 5
58 Lbs and #2
__________________
72 Chevelle convert. 2002 Zo6 block Comp Cam 566/566 224/224 @114 LS mallett stage 2 ported ls1 heads, Zo6 intake Billit Speed Inc fuel rails, Sumped tank, Aeromotive A1000 pump And adj reg. braides lines 36# inj.s ported TB High flow oil pump HD timing chain, Mid length S&P headers dule stainless steel X-pipe no cats 2.5" magnaflow system. HiPo built 4l60E 3200 stall. 4:11 gears.
98 Vette Vert. Ported heads and Zo6 intake 03 Zo6 Cam.
72ChevelleConv.LS1 is offline   Reply With Quote
Old 10-10-2006, 05:44 PM   #13
Quick Double Nickel's Avatar
Trader Rating: 5
Which method does the stock '97-'98 vette lines use?
__________________
'55 Chevy 210
'90 Mustang 5.0
Quick Double Nickel is offline   Reply With Quote
Old 02-23-2008, 10:17 AM   #14
streetcar540's Avatar
Trader Rating: 0
Send a message via Yahoo to streetcar540
Cool aeromotive 13109 fpr question
I had a friend tell me that this regulator has to have vacuum reference hooked up to be adjusted and work correctly.......aeromotive told me, if my setup originally had vacuum reference to hook it up, but if it didn't.....don't hook it up. My setup is 6.0L/L92 head/02' camaro computer, L76 car intake with single fuel rail inlet. I was gonna hookup like pic #1......do I, or do I not, need to use vacuum reference on the aeromotive 13109 fpr?
__________________
There is always a faster car than yours!!!!
streetcar540 is offline   Reply With Quote
Old 02-23-2008, 02:26 PM   #15
LS1MCSS's Avatar
Trader Rating: 16
I have used the Aeromotive regulator without vacuum and the pressure was steady from idle to WOT.
__________________
Old 02-23-2008, 07:26 PM   #16
Trader Rating: 3
Increasing the pressure at the rail increases the effective lb rating of the injectors. For example SVO 30 lb injectors are rated at 30 lbs for ford vehicles but act more like 36 lb injectors at the gm fuel pressure. Of course there is a limit to how much you can crank up the pressure.
__________________
http://i13.photobucket.com/albums/a2...Pete09copy.jpg
228/228 .588/.588 112 LSA
353hp/353tq unlocked
12.70@108 in 1/4
3290 Lbs
pist0lpete is offline   Reply With Quote
Old 04-25-2012, 12:39 AM   #17
ssdungeon's Avatar
Trader Rating: 16
Default part number
Does anyone have a part number for this? I want to mount mine on the fuel rail on the vette.
Quote:
__________________
Z28 - 404 LT Headers|H/C|FTRA|ASP UD Pulley|Borla|T/A cover|160 Stat|LCAs|LCARBs|Panhard Bar|Adj. TA|racetronix FP|Ported FAST92/92|42lb inj|Tick MC|PRO 5.0|STB|S2 T56|4.10s|RAII| K&N|LID|Spec
C5 - 408 1 7/8" LTs|3" X pilpe|UD Pulley|42lb inj|Spec|Wet Direct Port|Ported FAST 92/90|VARARAM w/Power Duct|Tik MC|HPT PRO|Snap Shifter|160 Stat|Mz6 S2 T56|DMH LP Cutouts
http://drsshook.shutterfly.com/pictures
ssdungeon is offline   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
13109, aeromotive, bypass, fpr, fuel, ls2com, mount, nova, place, plumb, plumbing, pressure, rail, regulator, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
