Edelbrock 7118 carb kit problems and questions.
Old 11-14-2006, 11:29 PM
Zedzag's Avatar
Default Edelbrock 7118 carb kit problems and questions.
I've got the 7118 carb kit and was there is an extra port for a plug in on one side. What is supposed to plug in there?
Also, anyone bolt a holley 4150 style carb DIRECTLY on the 7118 manifold? I had to grind the carb pad a bit because one of the accelerator pump housing bolts on each float bowl was contacting the manifold. The float bowl was touching the spark box as well. I think edelbrock wants a spacer with the holley carb.
I managed to fit it all under the stock 81Z scoup by not using a spacer and moving the spark box to the firewall. I'm using a 14x3 drop base filter and I opened up the factory hole in the stock hood.
Old 11-18-2006, 09:00 PM
TJ
TJ's Avatar
an electrical plug in on the box, or a port on the intake?
Old 11-18-2006, 09:30 PM
87ssMonte's Avatar
if it's the 2 pin plug, it's for the "chip"..
Old 11-18-2006, 10:07 PM
Zedzag's Avatar
The plug in is on the box and is opposite where the wires come out. It's a female port where a 9 pin plug inserts. There's a plastic cover on it that says "Cinch". It looks like some sort of ALDL plug. Could it be programmable somehow?
Old 11-19-2006, 11:19 AM
TJ
TJ's Avatar
thats what i asked edelbrock about.
my questions were never answered.
now that the MSD unit is out, i hope edelbrock loses sales on their kits, but there wil always be the guy thats wants something simple, in one box, ready to go, so they will still sell like mad.
Old 11-19-2006, 12:30 PM
Zedzag's Avatar
Does your edel box have the same port? Maybe since MSD builds the boxes, they built that port into all boxes, even the edel ones which were never intended to be programmable. Kinda makes sense that way.
I bought mine used but "still in the box" from a guy who changed his mind. Saved tons of money that way. I'll probably upgrade the box later.
Old 11-19-2006, 07:35 PM
TJ
TJ's Avatar
yea, same port.
my buddy has the msd, and they have a handheld unit like a hypertech so you can set you rpm limits and 2 step and nitrous if you dont have a laptop or a computer accessable.
wonder if the box was plugged in would it control the box?
i might have to get it from him.
Old 11-20-2006, 08:10 AM
caged02's Avatar
I hope someone finds out, I have been wondering the same thing about that port.
Old 11-22-2006, 06:46 PM
justin b's Avatar
Default edelbrock box
i called msd and edelbrock,they said there is no adjusting the edelbrock box.i was trying to figure out if i could retard it for nitrous,oh well,just buy another box
Old 11-22-2006, 06:56 PM
TJ
TJ's Avatar
i just sold mine too.
got an msd here.
its pretty trick.
Old 11-22-2006, 07:11 PM
justin b's Avatar
how much was it,did it come with the harness also?
Old 11-26-2006, 10:55 AM
TJ
TJ's Avatar
300 from jegs.
comes with everything.
for 100 bucks you can buy a lil box to program the rpm limits if you dont have a laptop.
its pretty trick.
will be nice to have a rev limiter again.
Quick Reply: Edelbrock 7118 carb kit problems and questions.
