ls1...eerrr SBC rx7 *56K* Danger to manifold
Old 03-24-2007, 11:11 PM
cyipher's Avatar
Default ls1...eerrr SBC rx7 *56K* Danger to manifold
I usually stick to the nitrous forum but I figured I would venture a little and post in here.
Hurst Pro-matic 2
Battey Box
Full coilover with kyb adjustables
5 Gallon Fuel cell & A1000
Mallory reg and -10AN line
The power plant
underside
Ignition
Digital 6
I love ceramic coating
tranny cooler
Overview
noids
WOT Switch
Bottle
Hood
Old 03-24-2007, 11:27 PM
fccs's Avatar
well thats something different..
Old 03-25-2007, 02:58 PM
NemeSS's Avatar
it will move,
Old 03-25-2007, 04:41 PM
THE_SUPRA's Avatar
that wont be fun at all!
Old 03-25-2007, 05:07 PM
cyipher's Avatar
hoping for low 10s on the bottle
Old 03-25-2007, 08:35 PM
tirefryin_s10's Avatar
sweet looks alot like my old first gen rx7 went 12.5@115 all motor on a 700 dollar 355 with vortec heads stock diff etc
Old 03-25-2007, 08:49 PM
cyipher's Avatar
im already collecting parts for my next motor build...
Old 03-26-2007, 01:35 PM
what diff you running? with a 26" tire and a th350 i was crossing the traps at 6800 rpm unless you got osmetyhing then the 3.90 i hope that motor sings to the moon
Old 03-26-2007, 10:03 PM
cyipher's Avatar
took to the track today and im gonna need some different gears... 23's with a 3.90 equals no mas...
Old 03-27-2007, 02:14 AM
LOL exactly what i thought but there are no gear oiptions unless you goto the 8.8 which is a far better way to go
Old 03-27-2007, 09:57 AM
cyipher's Avatar
do they make an 8.8 that bolts in other then the grannys conversion.
Old 03-27-2007, 10:22 AM
Nate81Camaro's Avatar
WOW! Talk about a sleeper!!! Looks nice, I didn't know there was that much room under those! (I know guys do LS1 swaps quite often, but I have yet to see pics of the engine bay)
Old 03-27-2007, 11:06 AM
cyipher's Avatar
they have low rise manifolds to clear the hood too, but i have vortec heads on there and as far as i know, no one makes a low rise for them.
Old 03-27-2007, 11:59 AM
silicone boy's Avatar
Very NIIIIICE!
Old 03-27-2007, 09:33 PM
the combo seems very similar to what i had in my car mine was as follows
81 rx bare bones
355
10-1 hypers
comp xe 274 cam
performer rpm
770 vac secondary carb
all msd ignition
shorty headers
single 3"
2800 stall
th350
ran 12.5@115 mph N/A on bald *** 235/60/15 street tires with the stock diff etc as for the 8.8 lots of guys cut the brackets of a stock diff and weld them on and go that route and just my 2 cents lower the A1000 pump to below the sump of the cell otherwise it will overheat in any kind of street conditions etc
Old 03-28-2007, 10:32 AM
cyipher's Avatar
81 rx bare bones
355
10-1 hypers
comp xe 274 cam
performer rpm
all msd ignition
shorty headers
single 3"
2800 stall
th350
mines an 85 not sure what model, i know it has power windows. I still need to get it to the scales, and find out what it weighs. i was reading aeromotives instructions and it stated it should be mount at or below the center line of the tank, but i have enough room im gonna move it.
What rim and tire combo did u use?
Old 03-28-2007, 10:35 AM
i used mustang ten hole rims and bfg 235/60/15 for street along with drag lites and 26x9x15 slicks for a 4 lug mustang on mine i also converted the rear to take normal studs instead of the gay *** lug bolt things .......but i would strongly recomend a 8.8
Old 03-28-2007, 11:05 AM
cyipher's Avatar
i think im gonna go pull another rx7 rear and a 8.8 outta a ranger or mustang and just make my own, i know that grannys sells a torque arm conversion but i think my car hooks well for having the watts link, my front suspension is adjustable with 7" long 350 "/lbs springs, I also have both sway bars on, which im gonna pull off today so that should help.
Old 03-28-2007, 05:58 PM
just pull the front bar not the rear and your right about leaving the suspension set up like factory just beef up the 4 link arms as they like to bend i cut a 1.65 60 foot on bald *** bfg street tires in mine with no suspension work at all and all motor
Old 04-01-2007, 09:48 AM
cyipher's Avatar
Pulled the front sway bar and im going to to track today hoping for 12's on motor but if i dont hit 12's its cause im 4800 ft asl.
Quick Reply: ls1...eerrr SBC rx7 *56K* Danger to manifold
