Ls2-4l80e Chevelle **UPDATED WITH PICS**
Old 01-22-2008, 08:31 PM
  #41
john 67's Avatar
yes i've been on the phone with ati for exactly that setup, still waiting for them to call back,i'll make my own brackets for the comp.. i used all stock setup for the acc. i dont have the reciepts near me right now but i can get you the prices if you need.its ati that made the pulley, right? who is fluid damper? ive been waiting a couple of weeks for ati to get back to me thanks,. john
Old 01-22-2008, 09:54 PM
  #42
65SSZO6's Avatar
John,
Try ATS American Touring Specialties, they are marketing the balancer with a conversion kit for the LS7 to go into a first Gen Camaro.Maybe they have the balancer you need.Yes,I believe it is ATI that makes the Fluid dampener.
ATS 702-245-6305 or www.t56kit.com
P.S.Let me know where you got your accesory drive parts and $ if you can.I might be interested in your balancer if ATS can help you out.
Old 01-22-2008, 10:10 PM
  #43
john 67's Avatar
thanks .balancer will be available if i get the new one,i called goldens chevrolet parts in P.A, scptt helped me out ,i originaly purchased the base engine then later ordered the front acc. he looked op all the #s for me . ill get u the $ when i dig out the reciept , maybe i could fax it to you? im going to at right now. thanks JOHN
Old 01-26-2008, 03:58 PM
  #44
65SSZO6's Avatar
John any update on your balancer search?If you find a replacement,what would you sell your oe one for?
Old 01-26-2008, 06:45 PM
  #45
john 67's Avatar
no status yet i'll try them again on monday.im not sure what its worth i guess 1/2 price but it wouldnt be available until i get a new one and install it,my project is kind of slow moving.i dont knov if this fits into your time frame .JOHN
Old 01-27-2008, 05:11 AM
  #46
OneQuickCoupe's Avatar
Your build looks good John. Good looking set of headers. What tube size are they and how much? Also can you get different size exhaust pipe sizes with them? In other words the bolt on street hookup collector.
D.J.
Old 01-27-2008, 11:21 AM
  #47
john 67's Avatar
HEADERS are from s&p 1 1/2" tubes , 2 1/2 " collector size ,560$ they are shorty headers with their own bolt on collector flanges with o2 bungs . i dont think they would be compatible with any other system. JOHN
Old 01-27-2008, 07:43 PM
  #48
john 67's Avatar
Here is my homemade trans. cross member made from 1/2" x 2" steel w/reinforcement pieces welded in. Made some perches out of angle iron also w/reinforcement pieces that I will bolt in:
Old 01-27-2008, 10:23 PM
  #49
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
You can run this accessory drive system from Schwartz Extreme Performance.
Andrew
Attached Thumbnails Ls2-4l80e Chevelle **UPDATED WITH PICS**-schwartz_acc_drive.jpg
Old 01-27-2008, 10:47 PM
  #50
ThaBirdMan's Avatar
Pure Sex.
Old 01-29-2008, 04:44 AM
  #51
john 67's Avatar
old crossmember weight 11.76 lbs
new crossmember weight with perches 19.08 lbs
a difference of 7 1/3 lbs JOHN
Old 02-06-2008, 05:23 PM
  #52
kevin 67/6.0's Avatar
John thanks for all your help. I see you are using a 4l80 trani I was wondering what gear you were going to run. I am still thinking about that one. I only have a 10 bolt but that will have to go. I Found a 12 bolt for 350 dollers. I just got to get the money.
Old 02-06-2008, 06:18 PM
  #53
john 67's Avatar
373"s in the rear
Old 02-18-2008, 03:50 PM
  #54
Qwkss's Avatar
still lowering the body down... has a vette accessory drive . i ordered it with everything but the a c components . i know there are clearance issues so ill address that later after i get the oil pan-steering & tranny squared away
Very cool build.
Where did you order the vette accs. drive from?
Old 02-18-2008, 07:38 PM
  #55
john 67's Avatar
thanks. I ordered it new from g. m. goldens chevrolet in p.a.
Old 02-18-2008, 08:19 PM
  #56
pitbull14218's Avatar
I dont know if anyone noticed but the slotted rottors on the first couple of picks look like there on the wrong side, looks backwards to me, and if someone allready said this sorry, there was 3 pages and i didnt want to read all the posts. nice though
Old 02-19-2008, 12:49 AM
  #57
Qwkss's Avatar
Any certain part number? What kind of price?
Keep the pictures coming!
Old 02-19-2008, 10:44 AM
  #58
chree's Avatar
When the collector gaskets blow out go ahead and choke up the $20 each for copper collector gaskets from S&P. I also used longer collector bolts and used two nuts per bolt. The collector bolts had a habit of loosening which of course blew out the collector gasket.
(My application is S&P shorty headers on an LT1, but the collector is the same.)
Old 02-19-2008, 07:04 PM
  #59
john 67's Avatar
thanks for the info, i didnt know this was a problem . I'll keep my eye on it when i eventually get it running, JOHN
Old 02-19-2008, 08:00 PM
  #60
john 67's Avatar
you know i did notice that a while ago, the rotors came pre assembled onto the spindles.i would assume that the curved interior of the rotor is supposed to " scoop " tha air into the rotor as the wheel would be moving foward ? the slots on the outer parts are in the opposite direction. i"ll call wilwood tomorrow . thanks for the keen eyes.JOHN
Quick Reply: Ls2-4l80e Chevelle **UPDATED WITH PICS**
