Is a ls2 gto oilpan the same as ls1 gto oil pan
Old 06-11-2007, 11:59 PM
ronald so's Avatar
Default Is a ls2 gto oilpan the same as ls1 gto oil pan
I ran into a good deal and wanted to make sure.
Is a LS2 GTO oil pan and front sump assembly the same as a LS1 GTO oil pan setup?
Also since I'm already here. I'm running -6 lines for fuel, what do you recommend as far as a FPR?
Also I'm trying to order the special fittings to use on the stock rail
http://store.summitracing.com/partde...art=RUS-640850
and this is a 3/8in or -6
http://store.summitracing.com/partde...art=RUS-640860
it says its a 5/16in so in other words it uses a -5 line for fuel supply Why would the supply line be a smaller fitting.
Thanks ronald
Old 11-27-2007, 06:38 PM
bishoptaner's Avatar
i am trying to figure out the same thing, does anyone have the answer?
Old 11-27-2007, 09:39 PM
itslow's Avatar
Yes, the same.
Old 11-27-2007, 10:28 PM
thank you
Quick Reply: Is a ls2 gto oilpan the same as ls1 gto oil pan
