Aftermarket oil press guage fitting?
Old 06-14-2007, 01:58 PM
Ionize's Avatar
Default Aftermarket oil press guage fitting?
Anyone know what conversion fitting is needed to use a traditional (non-metric) elect or mech oil guage in the stock sensor location? Haven't bought a new guage for my t-bucket yet so I can do elect or mech, I already have the conversion fitting for the water temp sender setup. thanks!
Old 06-14-2007, 02:21 PM
hpmotorsports's Avatar
on the side of your block next to the oil filter there is a blockoff plate, I just drilled & tapped it for oil pressure
Old 06-14-2007, 02:50 PM
12secSS's Avatar
M10 to 1/8 NPT.
Found here: http://www.egauges.com/vdo_acce.asp?...apter_Bushings
bczee's Avatar
I did the same for my Oil pressure gauge..
Since I want to use my stock idiot light for my chevelle. I took the LS1 sender on the top/back of the block, broke off the top, drilled and tapped to the thread size of the Chevelle sender and used it as a adapter. Now I have both the gauge and idiot light.
Equus make a adapter for the 12x1.5mm to NPT.
For the passenger side head water temp. I just took out the plug and drilled and tapped it to 3/8" NPT for the Temp sender. No adapter needed.
Old 06-15-2007, 09:41 AM
Ionize's Avatar
Thanks guys for the info!! Pics of completed project soon.
