Oil pressure range 2002 LS1
Originally Posted by DLSNFL
What are the ranges for oil pressures?
cold start?
Hot idle?
cold start?
Hot idle?
Application
Specification
Metric
English
General Data
Engine Type
V8
Regular Production Option (RPO)
LS1
Displacement
5.7 Liter
346 CID
Bore
99.0 - 99.018 mm
3.897 - 3.898 in
Stroke
92.0 mm
3.622 in
Compression Ratio
10.1:1
Firing Order
1-8-7-2-6-5-4-3
Lubrication System
Oil Filter Type
PF44
Oil Type
5W-30
Oil Capacity (With Filter Change)
5.2 Liters
5.5 Quarts
Oil Capacity (Without Filter Change)
4.7 Liters
5.0 Quarts
Oil Pressure (Minimum - Hot)
At 1,000 RPM (Revolutions Per Minute)
41 kPa
6 psig
At 2,000 RPM
124 kPa
18 psig
At 4,000 RPM
165 kPa
24 psig
I've had my conerns about low oil pressure with
my 2002 LS1 and chasing down possible problems.
I have at hot idle possibly 10psi and at higher
rpms......20-25psi. So these engines don't have alot of
pressure? Seems strange to be so low in my book?
My LQ4 idles @ mid-30's but then goes up around 50psi when I gas it, is this normal?
What oil pressures are you other conversion guys experiencing??
For anyone with stock oil pumps (not aftermarket or ported)... what are your oil pressures?
I've searched and there are oodles of threads talking about oil pressure problems, but once the problems are fixed none those threads include the resulting oil pressures.
Maybe this thread can become a future reference for oil pressure variation for whoever might search it up...
My 2002 at 185 deg idles at about 35 psi, at 1900 rpm it's around 40, and under full throttle it's 58 or so . At least that is what the video showed on my first launch. I have a mechanical gauge and I run 5W30 mobile one. And to thank I was one of those guys that had zero pressure for the longest time after I got it running.
