Fuel system plumbing with a returnless system
2000 LS1 motor with single fuel inlet. We have a modified fuel tank from Rock Valley that has 1/4 NPT going in and going out. Does anyone make a rear mounted regulator system to that can be used so we can retain the stock one line to the rail?
Thanks guys!
On the inlet and return, I'm using the Russell quick-connect to AN adapters. They don't fit very vell, btw. Some people use compression fittings. On the outlet, I used a Dorman tube and a compression union to connect to a shortened/bent reproduction 3/8" stainless hard line. I think the Russell and Dorman part #'s are in one of the stickies.
9 Second Club/LS1TECH Sponsor
We've done the Vette filter/Russell fittings on several setups. It works well.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
We make that tube here. That allows for a full quick disconnect system with no compression fittings.
__________________
www.speartech.com
www.speartech.com
