Oil Pressure Gauge Sender Location
Where are you getting your oil pressure info from, what part
of the engine is your sender (if using sender) located and did you have to
modify anything to make it work?
I ask because I am chasing down my low oil pressure problems,
and got under the car last night to start taking everything
apart AGAIN, and noticed an oil leak. I have the same set up as SMAX
where I used the old stock sender and drilled it out. But got to thinking
that maybe since it was leaking there it might be giving me false readings
also????? Anyway I thought one place might be better than another.
So I have re-built my oil sender device, but have not checked to see
if this is the culprit, betting it isn't.
NISMOSILVA270R......In my set up there is no provisions of any
kind to monitor the oil in any way with the PCM, either oil pressure
or oil level.
or oil level.
or oil level.
or oil level.
id like to use the factory locations with aftermarket senders/gauges, but i dont want to be throwing codes or run improperly (limp mode).
Coolant is monitored I'm assuming to turn on the fans.
Other than that its all the important stuff like crank, cam,
maf, air temp sensors that should be on a 'take out' engine.
Coolant is more than just for fans. it also lets the PCM know the engines temp for one of many variables for fuel and timing. Its a very important part of the electronics really.
after reading this:
https://ls1tech.com/forums/generation-iii-external-engine/74931-water-temp-gauge-install-questions.html
i see that there is a location opposite the factory location.
Ill run them both throught each of the heads
Put your aftermarket temp sender in the passenger side head at the back. Theres a plug there, pull it and install your sender. You might need the metric adapter though.
what eagleuh 1 said you can put it in the back of the pass haed with a metric adp. and it will go to an 1/8npt for a sending unit the plug is just a allen head bolt hope this helps
