alternator and idle problem
first which pin do i use to make the alternator charge i do not have the plug with it bolted to the motor with a 99 f body brackets i used the 2nd pin from the motor side
next after start up it wants to die right off idle the motor and computer was tuned in my camaro before i pulled it out and put it in a rock crawler and by the way it has a tr224/224 cam in it with a 350 turbo trans the car it came out of was a 6 speed thanks for the help
pin "b" should be the third one from the eng. it is abcd from the out side in.
run it to the pcm. if you run this wire to the ign. switched power you need a 470 ohm resistor or it will burn up the regulator
