5.3 in a 2wd 72 blazer (oil pan problems)
Alright, heres the problem afriend of mine an I are putting a 5.3 into a 72 blazer the blazer was 4x4, so we put a 2wd crossmember (channled 2 inches) in the truck and and air ride technologies strong arms on it.. The problem is the 5.3 oil pan is approx. 8 inches deep, and hits the ground when the truck is layed out. Also we have put a 5.7 LS1 in a 68 c-10 (with the same style crossmember) and doesn't have that problem because the LS1 oil pan in only approx. 6 inches deep..
So long story short will a LS1 5.7 oil pan work on a 5.3???
And if so what parts will be needed to make it work (ie sump, pick up tube)????
Thanks,
James
Thanks,
James
Here some pics, the finder thats on it is just to see how much of the fender needs to be clearenced (the front clip is already painted just not on the blazer yet)..
Thanks,
James
Thanks,
James
bczee,
The other truck my buddy has is a 1968 c-10 has a 2000 Ls1 out of a f-body, and it fits fine..
The problem is the truck pan on the 5.3 is about 2" lower than the crossmember..
He got the entire motor/harness & computer for a damn good price, so he went with the 5.3 or the truck would be gitting an 5.7 LS1.. And he stole my brand new 700r4 I was saving for another project..
Tomarrow I will try to find a f-body oil pan and pick up tube..
Thanx everyone for your help.....
sawzall wielding director
The f-body pan will fit, but you will need the pan, pickup, windage tray, dipstick and dipstick tube.
You will also want to get a new o ring for the oil pickup tube (get one for a f-body, the truck one is different and won`t seal on a f-body pickup)
You can modify the truck windage tray to work with the f-body pan (cut the front of the tray off where it covers the front 2 cylinders and then cut a new hole for the pickup to bolt on as it bolts to a different maincap stud) but you are much better off just buying the f-body tray, you will spend a couple hours making the truck one fit and a new f-body one is only around $30
hey I am doing a 5.3 swap in a 73 2wd blazer, I was just wondering If you use the stock tranny crossmember, what did you do to mount the tranny? looks like you could just use a spacer, but how big?
