LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
Old 09-10-2007, 02:16 PM
Mike96z's Avatar
Default LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
Alright, putting a 99 LS1 in my 96 camaro, now I heard that everything will work except for the Tachometer, in which you have to use an adapter for but I cannot find this adapter, what must I do to get the tach on my LT1 Guages to work with this LS1 engine?
Old 09-10-2007, 02:36 PM
Mike96z's Avatar
nvm found it
http://www.dakotadigital.com/index.c...rod/prd127.htm
Old 09-10-2007, 09:45 PM
sawzall wielding director
G-Body's Avatar
I don`t think you need an adapter box, you just need to reset the output in the PCM. It can be reset with HPTuners and EFILive, you need to reset the low and high resolution to 6 instead of 3.
Old 09-10-2007, 10:43 PM
daniel6718's Avatar
dont need the box, many will tell you you will but you dont
Old 09-12-2007, 01:41 PM
protwin's Avatar
Default question
my 383 just slung a rod and i am thing of put a ls motor in my car what info can you give me in the cost of a swap
Quick Reply: LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
