trouble with stock harness
I am having trouble trying to figure out how to hook up the stock computer and wiring harness. I bought the motor as a pull out and don't have the donor car. I have the entire wiring harness without the dash harness and fuse block. what is the simplest way to hook up the wtock wiring harness.
thanks Josh
thanks Josh
Buy the stock underhood fuse box and go from the engine wiring harness connectors, underhood fuse box connectors to your cars harness connectors. Get the wiring diagrams, connector pinouts from here,(frequently asked questions) or places like AlldataDIY.com. Then sit down and figure out what you need and where to connect it too. Good luck
