fuse block ?
fuse block ?
tryin to get some stuff together for a future project but have some questions, if someone could help me out
1. have a 98 LS1 engine/T56 harness, how does the underhood fuse block intergrate with the engine harness ?
2. since i have a 98 harness, how does the alternator charging work or what do i need to do to make it work ?
all for now....TIA
all for now....TIA
At least for the 99-up the engine harness does integrate with the dash harness actually but its not completely necessary to get that fuse block because you can just plug the appropriate power wires into a custom fuse block or if you have room in your factory one.
The three white connectors that are non weatherpak style that go through the firewall are the ones that connect into the dash harness. From what I can tell these are also the wires that provide power to the computer for switched and constant power. Therefore, they must tie into the fuse block either directly or though the dash harness. My guess would be it ties in through the harness rather than plugging directly into the fuse block.
Try the below link and download the Pdf file. It should help you immensely.
http://www.ls1tech.com/forums/showth...ferrerid=48206
BTW, keep in mind, some of the information about the Heads is incorrect in that book. I actually purchased the hardcopy about 4-5 years ago and some of the information on the heads isnt accurate. Also, starting to think some of the information related to the flywheel isnt 100% accurate either since I ordered one and its not correct.
Originally Posted by oange ss
thanx for the link...but i still cant verify what the other connectors are for, if they are the c100,c102 etc connectors, there is no way to tell.....
