Neutral Safety and TCC Wire?????
I am putting a iron ls1 in a 67 c10 with a 4l60e. I have nearly everything hooked up. The tcc wire, I have a brake switch for a mid 80's chevy truck that has the four prongs. I assume that the front two are for the brake lights and the rear are for the tcc?? Looking at the switch from the front will the left terminal on the rear get 12v and the right terminal get the tcc wire?
The neutral saftey switch, the coulumn is from a 70's chevy van that has the switch at the bottom of the column. I think it has a green and purple wire hooked to it. Which wire does the wire from the harness tie into?
Thanks for any help guys.
