VSS to Speedo????
VSS to Speedo????
I have TPI Gauges and they have 2 wires that say pulse generator. One is black and one is white. Can I hook up the VSS wire to one of these? I talked to the tech guy, and he didn't sound to sure of himself, but he told me that there is 2 wires on the tail housing that i need to hook into and not to use the VSS. Does this sound correct?
Thanks.
- Andy
Thanks.
- Andy
Thanks.
- Andy
Thanks.
- Andy
you need to know what specific signal they need per mile. such as the F-body cars need 4000 pules per mile
with out the pcm to change the signal from the sensor on the trans you would need something like a digital dakota box (sgi5 ? sorry but I can't remember if that's the correct name it is called ) anyway you need to convert the signal from the sensor unless your speedo has a internal calibration setup then you can run a raw signal
Thank you for the info. I thought it wouldn't be that easy. But still fairly easy, as all i have to do is connect the two wires to the tail shaft with no pulse generator. TPI gauges are fairly new and from what i can tell pretty cool, the website is www.tpigauges.com
