Truck oil pan
Old 10-25-2007, 01:29 PM
fast400's Avatar
Default Truck oil pan
Seeing how the truck oil pan is too low...has anyone tried cutting 2" out of the deep end, then welding the bottom back onto the pan? Any reason this can't be done?
Old 10-25-2007, 02:08 PM
Bo185's Avatar
Why when the F-body pan is already higher than the trucks. Save time and money.
Old 10-25-2007, 03:21 PM
QSPres's Avatar
So is the CTS-V pan...and the sump is further back towards the flywheel.
Problems arise when cast materials are cut and welded...
Old 10-25-2007, 03:29 PM
'JustDreamin''s Avatar
Reasons:
1.) Warpage. The amount of heat required to weld aluminum is sufficient to warp the casting.
2.) Contamination. Alum has some porosity, and the alum soaks up some oil, since its an oilpan and all. That causes difficulty welding (inclusions and other things).
3.) Other easier options. F-body, CTS-V, LS2 Vette, H3 Hummer all have different pans that are shallower at the sump. But in most cases you give something up (like the f-body pan is shallower at the sump, but deeper ahead of the sump, where crossmember clearance is usually at a premium).
'JustDreamin'
Old 10-25-2007, 03:31 PM
Bo185's Avatar
'JustDreamin'
Whats the H3 pan like? Is it similar to the trailblazer?
Old 10-25-2007, 03:35 PM
Bo185's Avatar
Googled it!
GM Partsdirect has them
Pan: 12600497 $117.00
Pickup: 12588480 $28.00
Tube: 12590590 $10.00
Dipstick: 12580811 $$9.00
Pretty cheap.
Old 10-25-2007, 05:41 PM
DCx
DCx's Avatar
im sure they will charge you that much for shipping too. that site is a total rip off.
Old 10-25-2007, 05:59 PM
Sled's Avatar
Originally Posted by Bo185
Googled it!
Pretty cheap.
Thats barely shallower... 1" shallower than the truck oil pan is still over 1" too low to the ground. The F body pan is still 2" shallower. CTS-V is 1" shorter at least.
Old 10-25-2007, 07:44 PM
Hotrod406's Avatar
I cut my truck pan down last week and it went fine. I cut it down to 5.5", same as an F-body. It only holds 4-4.5 qts now. How much does the F-body pan hold? Cast aluminum is challenging to weld, but not impossible.
Here are a couple pics:
Old 10-26-2007, 06:23 AM
QSPres's Avatar
Sooner or later, they're all going to develop porosity problems, as everything that's cast aluminum does...
Welded ones will just develop them sooner...
Old 10-26-2007, 06:53 AM
Jhankinson's Avatar
Stock F-body pan I think is 5.5qts. Stock truck pan is 6.5qts. I would not be happy with only 4.5qts...you can suck than dry pretty easy. especially if you ever wanna do some twisties. Even the guys running the fbody pans are over filling them by a qt when they get into race situations. So I hope you plan on somehow getting more oil in there somehow.
Old 10-26-2007, 07:28 AM
69LT1Bird's Avatar
You googled wrong, the H3 pan you listed is for the inline 5 cylinder engine
Old 10-26-2007, 07:34 AM
fast400's Avatar
Hey Hotrod,
It looks like you cut a good bit more than 2" out of the bottom! It looks really clean though. I was thinking of reusing the bottom and about 1" with the drain plug and just cutting out 1-1/2" to 2" out of the middle section, then weld the bottom back on. If done right it should cause porosity problems...or will it?
Old 10-26-2007, 08:03 AM
69LT1Bird's Avatar
The one in the picture is correct 12614821, just the listing of parts is wrong.
Old 10-26-2007, 08:34 AM
Bo185's Avatar
Just noticed it was listed wrong! Oh well, it looks almost like a truck pan anyway!
EDIT: Its sells for $114.94 shipped.
Old 10-26-2007, 09:05 AM
Steve VanS's Avatar
Come on you casting experts out there: We cut and welded a notch into our '04 GTO oil pan with no problems. The GM pans are die-cast and there is no porosity. Just wash the pan in the dishwasher first, cut and weld. We used 5052 alum for the patch and had an experienced welder TIG the patch in. He used 3/32dia 5356 alum rod and pre-heated the pan before welding. We had some distortion ~~ .06-.08 at each end of the pan, which the pan bolts pulled right down. See pics at:
http://forums.bimmerforums.com/forum...=699289&page=5
The pan pic is at the bottom of the page
Garret & Steve almost done with E30-LS1 aka 357is
Old 10-26-2007, 10:05 AM
Hotrod406's Avatar
I did cut a lot out of the pan. My car is really low so I didn't have much of a choice. The truck pan would have been .500" below the ground if I didn't shorten it. I'm not terribly happy with the capacity either. I might be able to add some once I see what it looks like in the car. I'm going to leave it this way until I get the headers built. Stock SBC pans are only 4qt, do the LS motors circulate that much more oil?
Old 10-26-2007, 10:15 AM
Steve VanS's Avatar
Oil capacity in a engine is not a function of lubrication, but cooling. It only takes a part of a quart to lube the internals; the rest of the oil is there to cool places like the underside of the pistons, the main bearings, etc that the radiator coolant can not get near. If you're not pulling a trailer, drag racing, running at high speed for extended periods, you can get by with reduced oil capacity. A 5-qt sump has lost 1qt when the dipstick bottoms out. If you're concerned, add a remote oil cooler if your vehicle does not already have one.
Old 10-26-2007, 11:06 AM
Andy1's Avatar
Though I probably would have incorporated them into the flat section that you added, you could fabricate some "wings" like the Corvette pan in order to regain some lost capacity.
Andy1
Old 10-27-2007, 09:29 AM
Rodder's Avatar
Exclamation
Having oil sitting in the pan does nothing for cooling. Having oil dripping off the parts you mentioned is what helps cooling, and you forgot to mention the valve train--there a ton of oil puddling up in the vavle covers at high RPM.
Oil pan capacity is a function of not sucking the pan dry running at high RPMs, so that you always have pressure to the lubrication circuits. There was someone on the forum here about a year ago that had done that very thing with a cut F-body pan at the drag strip.
Quick Reply: Truck oil pan
