Coolant air bleed in rear radiator pickup?
I'm putting an ls1 into a toyota prerunner pickup and plan to place the radiator behind the cab (no glass in cab) with the main coolant lines running under the cab. I'm unsure as to how I should treat the coolant air bleed that usually runs a small hose back to the top of the radiator. Can I simply bleed out all the air once the system is full and then plug it off or will air pockets develop?
Advice needed thanks.
Bert
Bert
Needs to be vented to a low pressure area of the closed cooling loop. Top radiator hose or some people drill a hole in the top of the water pump any convenient place, albeit, it really should be a higher point then the head pick off spot.
