Crank pulley removal?
Old 11-02-2007, 07:36 PM
QSPres's Avatar
Default Crank pulley removal?
How did you guys get your crank pulleys off? I can't seem to budge the bolt and I had a 2' 1/2" ratchet plus another 2' pipe on it and I couldn't get it to move!
It is a standard rotation bolt (lefty loosey), no?
Old 11-02-2007, 07:39 PM
rao
rao's Avatar
It is a standard thread. I use a 30" breaker bar and a home-made tool to hold the pulley in place https://ls1tech.com/forums/showthrea...t=#post4157612. Make sure you have a GOOD puller when you go to take it off.
Wait until you have to put it back on
Slow 346's Avatar
Its a standard rotation bolt. I use a tool to lock the flywheel in place so it wont move and my big breaker bar to loosen it. Most of the time even my air impact wont do it.
Old 11-02-2007, 07:41 PM
Ericbigmac83's Avatar
i used an extension about that size and then had my friend and i both pull on it, try getting someone to help
Old 11-02-2007, 07:42 PM
QSPres's Avatar
I'm not turning the motor over, I wedged a screwdriver between the frame and pulley, so that wasn't the problem.
The bot just won't come loose...
I have a stroker crank going in the motor, so I'm not really worried about damaging the crank, I just wanted to finish my mockup of everything with the F-body crank on it.. I guess it doesn't matter much...
Old 11-02-2007, 07:49 PM
Scooter70's Avatar
You just need more leverage. I think the torque spec is about 240ft-lbs so get the biggest breaker bar you can find.
Old 11-02-2007, 09:22 PM
pist0lpete's Avatar
I just used a 1/2 drive about 14 inches long plus another 24 or extension and just got mean with it and it came loose. Didn't damage anything in the process.
Old 11-03-2007, 01:44 AM
bczee's Avatar
I used a 4' pipe on the end of the breaker bar.. You will not have put to much into it with that much leverage! And was easy to get it to 240ft/lb and the 140 Degrees.
Old 11-03-2007, 06:46 AM
forcd ind's Avatar
i had to lean on mine pretty good, used an old bumper jack for a handle, i was lucky it came loose because i didnt have a metric socket that size and had to ues the closest american one
not to hijack the thread, but does anyone have a part # for a puller that will pull the balancer? i bought a couple 3 jaw, but cant get them to grip inside, just used them outside since i wasnt reusing the pulley anyway
Old 11-03-2007, 08:10 AM
01Z28M6's Avatar
Archimedes said he could move the earth with a lever long enough and a place to stand.
You just need more leverage. Mine came loose with a crack and a puff of powder. I used a 3 foot piece of pipe on an 18" breaker bar.
Old 11-03-2007, 09:06 AM
10 Second Moderator
Torkman15's Avatar
Good impact set on kill with 180 PSI line pressure took my crank bolt off so fast it flew half way across the room. Made a puller attachment out of a 3.4 WP pulley. Piece of cake.
Old 11-03-2007, 09:22 AM
QSPres's Avatar
OK, OK, OK... I get it guys!
Old 11-03-2007, 11:11 AM
bczee's Avatar
Use the Search....
https://ls1tech.com/forums/generation-iii-internal-engine/808118-anyone-rent-pulley-install-tool.html #12
Old 11-03-2007, 04:25 PM
ryanvv355's Avatar
breaker bar with 4' pipe, I did mine last weekend. I started a thread to becuase i couldnt get mine...
Quick Reply: Crank pulley removal?
