24x tooth reluctor wheel harness for 58x tooth motor?
Got a harness from a '05 GTO that I'm pretty sure had a 24 tooth reluctor wheel and I want to use the harness on with my '07 TBSS LS2 motor that for sure has a 58 tooth reluctor wheel. Is this going to be a show stopper or can I get the harness to work? I know I will need a PCM for 58 tooth car, but can the harness still be used or made to work? If it matters I'm using all of the GTO front accesories along with the GTO intake, TB, and injectors.
9 Second Club/LS1TECH Sponsor
No, that will not work. 58X ECM is not compatible with the 24X harness.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Can I send it too you guys and have you do your thing to make it work with my setup or trade it for a harness that will work? I have the entire harness including the gas pedal assembly. I would also need to get a PCM at the sametime.
You can swap the crankshafts, but I do not want to go that far into the motor unless I absolutly have to as a last resort. My motor is almost brand new with 8K miles on it...
