C3 LS1 w/carb...times and Vids
I am very happy with the times... for so few mods. 12.3 @ 111
680 Holley DP... TH350 3000 stall ... 224 Comp Cam... C5 exhaust manifolds... Mid America 2.5in Off Road Exhaust... Performer RPM Intake... 275/60r15 BFG Drag radials about 7 years old..LOL:crazy:
Scary thing is I know I can cut about .1-.2th off the time with little better Leave... New tires
http://s243.photobucket.com/albums/f...t=vette125.flv
http://s243.photobucket.com/albums/f...t=vette123.flv
Next Month 175 hp Cheater system goes on !!!
Yup the red... BOX with #4 chip
I will be upgrading the BLACK BOX with Retard Control
To run 175 Cheater system from My old Camaro....
Maybe I canget into the high 10s !!!
I am guessing my wieght at about 3250lbs.... I have to cut the front springs after motor swap... LS1 is much lighter than a sbc 350... otherwise it would look like a TONKA TOY....
I am running the factory rear with 3.23 gear... I have 275/60R15 tires... BFG drag radials... about 7 years old.
pretty neat-has anyone used the msd box in a switchover to FI-i thought with a harness, that same box would do fi-i planned to start out with a carb, latter switch over to fi maybe, and if the same box could be used temp. would be neat
with some tweaking, you will prob hit 11's
Beside the carb intakes flow better... and HOTROD MAG... has typically pulled better numbers with carb and intake
i meant fuel inj.-i was going to start off with a carb., once everything was up and running, maybe switch over latter to fi-i thought the msd box could do that with another wiring harness-i am running a d1sc procharger with a vette acc. drive, on an lq4 engine w/zo6 cam. I have run a bunch of prochargers, fig. would be easier to start with a carb., given my computer stupidability-im using a switch pitch turbo 400 trans at first, then might switch over to a 4l80e (already mocked it up once) i want to end up with good performance, middle to high 11's, quite so i can tolerate it driveability, decent rpm's on the road(doesnt everyone-lol)
update us on the vette, would like to see what it ends up doing
