ECM question
Old 11-20-2007, 01:26 PM
V8Rumble's Avatar
Question ECM question
Hey all,
I'm in the process of trying to prepare for my winter project (LQ9 swap), & since I really want to retain VATS, I've been told that I need to use an F-body ECM. The problem is that I don't know which ECU would be better to use - the site I've been checking lists both of the following as ECM choices for an '00-'02 F-body:
(ECM), (behind right strut tower), 5.7L, ID 9354896
(ECM), (behind right strut tower), 5.7L, ID 12200411
I suspect (based on a post in the ECM/programming forum) that the 2nd one might be the later model but both appear to have been used throughout at least 3 years of LSx F-body production. Both appear to have also been used in a large number of truck/van applications as well..
Does anyone happen to know the differences between the two ECMs/PNs??? Is one preferred over the other??
Thanks for any help you can give...
Old 11-20-2007, 01:46 PM
bczee's Avatar
I would contact John at Speartech.. He should be able to answer all your questions and get you going in the right direction. They are a sponser on this site.
Old 11-20-2007, 02:56 PM
slow's Avatar
they should both be interchangable, either should work.
ryan
Old 11-20-2007, 03:55 PM
sawzall wielding director
G-Body's Avatar
You should be able to use the truck PCM. I know that in the factory configuration the VATS can`t be bypassed, but in my HPTuners software I have 3 choices on the security screen
1. Serial
2. PWM
3. None
I have not tried it yet but if I put it on PWM instead of serial I should be able to use the VATS byapss box to make it run
Old 11-20-2007, 05:39 PM
V8Rumble's Avatar
Thanks for the responses guys, they're much appreciated.
I don't know if my intent was entirely clear, I actually want to KEEP the VATS function, rather than disabling it. I've been told that if I utilize the PWM type, I can retain it as I'd like to. (I've held on to some notes & PMs that people have sent me about that.)
bczee, that's a great idea, it's just one that I'm holding on to as a "last resort". I know that John's been REALLY good about helping people out (even when they're not buying stuff from him), but I suspect that he's already got plenty of things on his plate without having people bug him & add to the pile...
Again, many thanks guys.
Quick Reply: ECM question
